LinkBack | Thread Tools |
Rating:
#11 (permalink) |
Subaru Tester
Car: 1996 Subaru Legacy Outback 2.2L AT
seems i spoke too soon. I finally found a very useful link, very suprised how similar they are. according to this, i do have a LSD
LSD vs Open guts |
#12 (permalink) |
Wow, subtle difference! So when the LSDs go, it's because the clutch plates have worn out?
I wonder how much more expensive the LSD is to produce...doesn't look like it could be all that much worse. Makes you wonder why Subaru didn't put it in everything that didn't have VDC. |
#13 (permalink) |
Subaru Tester
No clutches. Its a fluid based coupling sort of like the torque converter in an automatic transmission, but the fluid in a vlsd is silicone based and thickens up as its heated. The coupling I beleive is attached to the smaller gear that the axle slides into inside the ring gear. The coupling tries to keep that smaller gear and the ring gear spinning at the same speed, when slippage occurs the fluid heats up and start the "effect". Once the smaller gear and ring gear are spinning the same speed again, the spider gears can then tranfer the power to both wheels evenly. This all happens in split seconds
#14 (permalink) | |
Great pics, and link! Thanks.
I believe the most common failure in the V-LSD is the seals, which separate the plate area from the rest of the differential. (It's that extended "housing" to the left of the crown gear in the pics.) Once the seals go, and the viscous fluid either leaks out, or becomes mixed with the gear oil in the differential, the gelling effect is lost. Loss or mixing of fluid could happen very slowly over a long time. The seals might still cause the drag that leads to both wheels turning in the same direction when manually rotated, but the LSD won't be effective. See also the attached description from my 2007 FSM, and http://en.wikipedia.org/wiki/Viscous_coupling_unit, which has photos of the plates (not Subaru LSD but essentially the same idea). (p.s., woops, see I doubled with no64terry). |
#15 (permalink) |
Subaru Tester
Other than the bushing bolts, the swap was painless. Axles clicked right in but wont be able to test it until I put the motor back in.
