Body Integrated Unit? What is it? - Subaru Outback - Subaru Outback Forums
post #1 of 12 (permalink) Old 11-19-2006, 09:16 AM Thread Starter
yyz2nyc's Avatar
Car: 07' OBW Silver AT
hello...very new Subie owner, love the 07 Outback 2.5i. But recently, the car, when from a full stop to approx 10 miles/hr on acceleration you hear a click or something like an electronic relay in the shifter gate. When you slow down, to below 10 miles/hr you'll hear the click again. Anyone else have this problem? I brought it to the dealer and they told me it was the Body Integrated Unit and needed it replaced, what does that control?
yyz2nyc is offline
post #2 of 12 (permalink) Old 11-19-2006, 12:45 PM
Hokey Pokey Champion
JazzyMT's Avatar
Car: '05 Gold OBXT Stg2+
The Body Integrated Unit seems to be a secondary computer of sorts to the ECM. It controls things like the air climate control, windshield wipers, power windows, immobilizer, display gauges - essentially, everything electrical that doesn't directly control the engine.
I'm not sure what the click is, but the good news is, the BIU is easy to replace & it's under warranty...let us know if they can tell you anything else about the problem.
When the Winds of Change blow hard enough, the most trivial of things can turn into deadly projectiles.
JazzyMT is offline
post #3 of 12 (permalink) Old 11-20-2006, 10:08 AM Thread Starter
yyz2nyc's Avatar
Will do...taking her in tomorrow...i'll find out more and post the details...thx.
yyz2nyc is offline
post #4 of 12 (permalink) Old 11-28-2006, 04:33 PM Thread Starter
yyz2nyc's Avatar
apparantly not easy to replace...had to take out the dash on my car. still in the shop for 2 days now. Is it that difficult, picking the car up tomorrow and will keep pdates.
yyz2nyc is offline
post #5 of 12 (permalink) Old 11-28-2006, 07:38 PM
JazzyMT's Avatar
Hrm...that's not what the service manual says. Says you remove the instrument panel lower cover (under the steering wheel) and there it is...one clip to take it out, one harness to disconnect. Should take a Subaru tech all of 2 minutes.
I'm having the blower motor for my heater replaced Thurs and they really do have to take apart half the dash to do that. They said they could do it in under an hour while I wait.
Not sure what you're dealer is up to, but I'm suspicious to say the least.
JazzyMT is offline
post #6 of 12 (permalink) Old 11-28-2006, 07:58 PM Thread Starter
yyz2nyc's Avatar
That's what I thought too....I'll ask tomorrow...kind of suspicious, been bothering me too. Thanks for the update JazzyMT, glad you have the service manual. I will post and let you know.
yyz2nyc is offline
post #7 of 12 (permalink) Old 11-29-2006, 03:25 PM Thread Starter
yyz2nyc's Avatar
Got the car back today. Seems the mechanic had some difficulty of some sorts, and had to look up the service bulletins. Anyhow, i questioned about how long it took (2 full days) when it should've been a "2 minute" job. Speechless...a lot of umms and ahhs. To top it off, forgot to reconnect my wiper de-icer relay, ignition illumination ring and scratched up my shift gate frame and made little indents on the heat seater controls! The clicking noise is now gone as they said it was a short circuit in the relay causing the "clicking" noise in the gate. Told me it also enabled you to shift out of Park to Drive without stepping on the brake first. thx again JazzyMT for the info!
yyz2nyc is offline
post #8 of 12 (permalink) Old 04-06-2007, 01:50 PM Thread Starter
yyz2nyc's Avatar
The problem has come back...sounds to me like a solenoid engaging in the shifter box? Anyone with some ideas? The things is, it now only makes a clicking noise when I decelerate just before i come to a stop it clicks, or when I reverse past 3-5 mph. I've also tried it with the manu-matic and it only clicks when it downshifts automatically from 2 to 1st. anyone...getting very frustrated. thx!
yyz2nyc is offline
post #9 of 12 (permalink) Old 04-06-2007, 02:37 PM
I'm Not Slash...yet.
FMGreen's Avatar
I don't know, but I'd surely recommend finding a different dealer.
Did they ever replace the parts that the scratched/damaged last time?
If you can't keep it clean, keep it green!
FMGreen is offline
post #10 of 12 (permalink) Old 04-06-2007, 07:53 PM
Feedback Score: 7 reviews
yyz2nyc
The “click” is probably the shift lock solenoid. The solenoid prevents the shifter from being moved into Reverse when the car exceeds, or drops below, about 6mph, or being moved out of Park when the brake pedal is not pressed. This is explained in the Owner’s Manual in the Starting and operating section (“Selector lever reverse inhibiting function”).
The solenoid is located on the left side of the shifter mechanism in the front center console.
I tried to see if there was a noticeable sound in my 07 (4000 km). I did not start the engine; rather, with the windows closed and the car in my garage (i.e. for a quiet environment) I turned the key to ON, attached my seatbelt and waited until the various checks were completed. At that point the shift lever could not be moved out of Park. When I pressed on the brake pedal, the shift lever could then be moved to the other positions. This indicates that the shift lock solenoid is mechanically working when it should, at least as far as the Park/brake pedal interlock function is concerned.
With the lever in Park, I listened carefully as I pressed and then released the brake pedal. I could hear only a faint noise, a very muted, dull, thud in the console area. It was certainly not something I would hear with the engine running or out on the road.
The shift lock solenoid itself acts on a lever that in turn either allows or prevents the shift lever from moving.
I would suggest trying the static test (quiet area, ignition ON, in Park, brake on and off) I described above, which, by the way is from the service manual. If you can duplicate the loud clicking as the brake is pressed and released, then I would tend to suspect the noise is coming from the associated mechanism; in other words, it’s caused by mechanical parts that are not exactly where they should be, or some insulating material (perhaps a bushing) is missing. It could be just a small adjustment. Unfortunately, access to the solenoid does require disassembly of the console area once again.
plain OM is offline
