touch up paint pen instructions - Subaru Outback - Subaru Outback Forums
post #1 of 3 (permalink) Old 02-14-2017, 05:32 PM Thread Starter
I have the newer touch up paint pen with the paint on one end and clear coat on the other end. I can't find the box it came in which had the instructions. Does anyone have the box and can publish the instructions or a photo of the box with the instructions on it? The labels on the pen itself are simply the warning labels and not the directions.
BrianP58 is offline
post #2 of 3 (permalink) Old 02-14-2017, 11:57 PM
Car: 2017 Subaru Outback Limited 2.5 -Tungsten
I could not post a picture but have typed the instructions on the box. I hope that this helps.
Instructions on the box:
Paint pen - Shake 20 - 30 seconds to mix paint. Start paint flow by depressing pen tip in an up and down motion on a hard test surface until paint begins to flow. Increase paint flow by depressing pen tip, minimize flow by decreasing pressure.
Abrasive tip - Use the pointed edge to remove loose paint and rust, or the flat face to smooth edges or clean larger areas.
To open - Hold container upright and twist the applicator grip counterclockwise for either the paint tip, brush, or top coat applicator. Keep upright when opening.
Paint Application - One coat prime and paint formula. Wipe surface with a clean lint-free cloth using rubbing alcohol to remove oil, wax, or grease build-up. Allow 30 minutes dry time for additional paint or top coat (clear coat).
Paint brush - Tapered brush for large chips and scratches.
Top coat application (clear coat) - Foam brush for top seal coat
bamward is offline
post #3 of 3 (permalink) Old 02-15-2017, 08:48 AM Thread Starter
Thanks for the info. I was dismayed to find several chips on the hood of my relatively new Outback but guess not too surprised after going through winter driving with rock salt on the roads.
BrianP58 is offline
