I'm want to know if it's possible to change the cd player with manual AC (pic 1) to auto AC (pic2).
The model of the outback is 2006 2.5I
Thanks for your support.
Technically yes, but it would be extraordinarily difficult.
The pictures you posted show only the control panels for the two different systems. What you don't see is the actual air handler, which is buried deep behind the dashboard against the firewall. Each control system has its own type of air handler.
You would have to remove the entire dashboard from the car, replace the air handler, replace the main cabin wire harness, the blower speed controller and probably 3 other things I'm forgetting before you could use the automatic control system.
If you want to do this swap because of something to do with the stereo, there are simpler ways. If the point of it is to gain automatic climate control, it's cheaper and easier to sell your car and buy one that already has it.
