OB Addict
Car: 2004 Subaru Outback H6 LLBean 1997 Subaru Legacy Outback Limited- SOLD!
My first time on the highway for a long drive wasn't what I expected it to be. The car was powerful, smooth, and fast, but my cruise wasn't working!
Here's what's going on: In 1997s, the cruise switch is on the dash behind the wiper stalk and next to the rear defroster switch. When I push the cruise button, the orange light turns on and tells me its ready to be set. But, when I push the little cruise lever down to set it, nothing happens. I checked the fuse that is for the cruise control in the passenger compartment. Is there another one in the underhood box? I have no idea why this is happening, and I'd love for it to be an easy and simple fix. Any thoughts would be appreciated!
Subaru... The Beauty of AWD. |
#3 (permalink) | |
Car: 2000 OBS 2.2L
Easy fix. 5 min tops. Hopefully yours is just as easy. |
OB Addict
Thanks for the replies, but mine's sadly an automatic. Which plugs should I check? I'll take a look tomorrow when its light outside and hopefully put up a picture.
#5 (permalink) | |
Car: 2000 OBS 2.2L
OB Addict
Sorry but I'm not really sure what I'm looking for. I have this odd square looking black plug. I checked the Cruise/ABS fuse and it was fine. What exactly on the pedal am I looking for?
#8 (permalink) |
Gallery Ninja
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2005
See that adjustment at the top of the image in the center? That should be your solenoid switch that activates your brake lights and stops the Cruise from working.
It might be another code that the ECU is calling out, preventing the cruise from working. Do you have a CEL?
Ancient moderator of color and bokeh. Boxxerace Outback Gallery: Click Here |
#9 (permalink) |
OB Addict
Are you talking about that little black plunger type thing? There is no CEL. We had the knock sensor done if that helps with anything???'
Besides the Cruise/ABS fuse, are there any others that could lead this to happen?
#10 (permalink) |
OB Addict
Wow so I guess my cruise actually does work. I tried it on the way home tonight. The odd thing is that the speed drops 5 mph before it kicks in and speeds back up to the set speed. Is this what should happen?
