just bought a 1999 legacy outback and have some repair questions - Subaru Outback - Subaru Outback Forums
post #1 of 14 (permalink) Old 03-22-2008, 10:35 AM Thread Starter
Car: 99 subaru legacy outback
I just bought a 1999 legacy outback at auction with 177k on the clock and am in the process of catching up all the maintenance on it. I pulled the spark plugs last night and you can see in the pic this is what i found. I do not think the original owner kept up with servicing very well. What i want to know from you all is what all should i do too the car to catch it up. When i picked it up the check engine light was on so i went by autozone to pull the codes.
P1443
P0440
P0325
P301
P302
P303
P304
I had them clear the codes and i drove it home which was about 8 blocks. I replaced the spark plugs with a new set of NGKs gapped to .041 as per the zones recommendations. The air filter was really bad so it was replaced too.
There is a sound i hear when i hit the gas i am trying to figure out. It is only audible when under load driving down the road. It is like a buzzing sound. When in park and I rev it you cannot hear it.
So what all do you suggest i do next to catch up on maintenance and possibly fix the buzzing sound? I was thinking these things
Oil change
fuel filter (where is it at and is it easy to change?)
pcv valve (does it have one and where is it at)
breather element (does it have one and where is it?)
Thanks all
Name:	spark plugs.jpg
hotairgypsy is offline
post #2 of 14 (permalink) Old 03-22-2008, 10:56 AM
hawg's Avatar
Car: 98 OBW 2.5 Ruby Red Pearl
Send a message via MSN to hawg
P1143 Pressure sensor circuit range/performance problem (low input)
P0440 Evaporative emission control system malfunction
P0325 Knock sensor circuit malfunction
P0301 Cylinder 1 misfire detected
P0302 Cylinder 2 misfire detected
P0303 Cylinder 3 misfire detected
P0304 Cylinder 4 misfire detected
Since you have already replaced the plugs that may take care of your misfire issue. Check the knock sensor to see if ti is cracked. If so replace it. The other codes need to be checked out as it could be a few different things causing them
1953 Harley FLE
1969 Camaro SS
1990 Cadillac Fleetwood
1993 Corvette 40th Anniversary Convertible
1994 Suzuki RF900
2000 Harley FLHTCI
2003 VDC Wagon
hawg is offline
post #3 of 14 (permalink) Old 03-22-2008, 11:11 AM
Low input means an open in a circuit, a high means its got a short.
Why they say input is that every thing is refernced to the ECU, not the individual sensor. A low input means that there is a low or no signal going into the ECU.
There isnt anything earth shattering here. Replace the wires with OE wires, also replace the PCV valve, and check to make sure the PCV valve hoses are not clogged.
Drive the car for a few days, then re read the codes. There is nothing there that is going to blow the car up, but the knock sensor may affect performance, so go ahead and replace that.
nipper
nipper is offline
post #4 of 14 (permalink) Old 03-22-2008, 01:19 PM
brianjglas's Avatar
Car: 1999 Legacy Outback
Congrats on your "new" car.
The buzz sounds like it might be one of the heat shields on your exhaust. If yiur can get under it try tapping the heat shields looking for a missing bolt, rusted out corner or something that moves a little bit. I found a rusted out corner on my '99 and used high-temp black rtv to fix it.
brianjglas is offline
post #5 of 14 (permalink) Old 03-22-2008, 01:24 PM Thread Starter
i just took it on a 20 mile drive and i got the check engine light too come on...read the code and it was a P0325...no other code...how do you check and add fluid to the front differential...i think that is what is making the noise cuz i think it is low
post #6 of 14 (permalink) Old 03-22-2008, 01:28 PM
brianjglas's Avatar
If you are still looking for the PCV and fuel filter, they are labeled in this picture.
The PCV is behind the plug wire and the fuel filter is a black canister with three ports/hoses.
Do you have a manual or auto, that makes a difference on the front diff.
post #7 of 14 (permalink) Old 03-22-2008, 03:11 PM
PO325 knock sensor is an extremely common code on these cars. Get a new knock sensor and replace it, it's a 10 minute job. Someone on here had a new one for sale a couple of days ago or go tosubarupartsforyou
I changed mine a couple of months ago.
Blacky is offline
post #8 of 14 (permalink) Old 03-22-2008, 03:19 PM Thread Starter
can the knock sensor be bad even if it looks fine? i have the automatic... what weight oil goes in the difs?
post #9 of 14 (permalink) Old 03-22-2008, 03:22 PM
Yes. It's a peizo electric sensor. It works like a microphone with a little sliver of quartz in it. It produces a very small ac signal. The quartz can fail, it can become loose, or the housing can fail.
nipper
nipper is offline
post #10 of 14 (permalink) Old 03-22-2008, 03:23 PM Thread Starter
here is the front of the knock sensor in there now
