#12 (permalink) | |
Car: 2011 Impreza OBS
Is it possible to pull a code even if the light is not currently on?
www.flickr.com/photos/bigalpha |
#13 (permalink) | |
i am tired but some place in this link http://www.endwrench.com/archive/sysdrive.html it says how the TCU works, if it holds codes, and how to retrieve them (without a reader). if no one else answers in more detail ill respond.... nap time Blu and i went 4 wheeling yesterday so both a little tired.nipper |
#14 (permalink) |
cool. Looks like a lot of good information. I'm going to delve right in. I need to go take my car off pavement sometime. The last time I did, it was fun.
#16 (permalink) | |
Ok one more time... it is NOT the obdII connector. PERIOD. To repeat myself "The light will flash if during the last operation cycl, there was an electrical fault in the tranny. This flashing is meant to catch your attention, and tell you you need to pull the codes. You can either search here for the method to pull the codes (it's NOT the OBDII plug) or get it to a dealer." That has NOTHING to do with the transmission. The tranny has its own computer, its own test connector, and its own codes. Read this then tell us what code you get. http://www.ultimatesubaru.org/forum/...+trouble+codes nipper |
#17 (permalink) |
Paladin
![]() ![]() ![]() Join Date: Jan 2008
Car: 2008 Outback 2.5i
I don't know if this helps or not....on my 97 Outback the A/T light blinked sixteen times in a row.....each and every time I started the car....my husband has a computer cd repair manual.....it said that if there was a problem, the light would blink 16 times each time you started your car.....the blinking would stop or reset itself after something like 40 car starts if there really wasn't a 'problem'....indeed after the 40 starts....the light quit the 16 flashes on start up....this phenomenon happened twice to me....both times after I had run it thru the carwash....don't know if it was the carwash or coincidence...but both times the light quit it's 16 blinks.....I guess if the light never cancelled or reset itself, my husband would have investigated it....but since it happened after the carwash, we just waited it out.
#18 (permalink) |
Alright. I took one of the grounding wires and stuck it into the #5 slot on the connector. Nothing happened. I turned the car to 'ACC' and still nothing. Then, I turned the car on and still nothing.
Either it's fine or I'm dumb.
#19 (permalink) | |
nipper |
#20 (permalink) |
Do you think that by testing the resistance in the system between certain plugs (as shown in diagmanual.pdf) I can find any problems in their infancy?
