AT OIL TEMP flashing - Page 6 - Subaru Outback - Subaru Outback Forums
Old 02-17-2013, 06:20 PM   #51 (permalink)
cardoc's Avatar
vegastriguy,
Your problem may be remedied with a pan removal, clean the sump screen and flush/refill. If yours has a spin on filter, take it down and look for debris in it. Clean it out before you spin it back on. If you take the pan down and see a lot of metal, budget for a rebuild or replacement. Other wise, you should see improvement.
SubarCharged
2001 VDC AWD Super Charged 3.0
Raptor VLLC Water Cooled Ultralight
Denso WRX 410cc Injectors (Soon DW650cc)
Silicone Intakes tubing w/GReddy TypeS
Type 13 WTA intercooler with 10x13 radiator w/7" fan
Aeromotive FPR & DW300 pushing E85
Innovate Motorsport WB, EGT, VAC/Boost Gauges
Projector HID Headlights/HID Fogs
Clarion DD, Polk Audio, Kicker Sub, SO M1350 Amp
All ECM Mapping by ED @ XRT
naysayers
All the goodies with an extra kick in the seat
cardoc is online now   Reply With Quote
Old 02-17-2013, 06:38 PM   #52 (permalink)
Thanks Cardoc...I will do that tomorrow....
vegastriguy is offline   Reply With Quote
Old 02-17-2013, 06:50 PM   #53 (permalink)
Park the car for about 2 hours, crank up the car for about 3 minutes, kill the engine. Check my fluids. Oil still good, AT oil still high.
Are you checking the AT fluid level with the engine off?
Old 02-17-2013, 06:51 PM   #54 (permalink)
I checked it both ways...with it on and off....which is correct?
Old 02-17-2013, 06:59 PM   #55 (permalink)
Car: 2003 LLBean H6 Outback
Warm, engine running, in Park.
Old 02-17-2013, 07:02 PM   #56 (permalink)
Ok, I just did it that way to make sure. My transmission oil level is above normal.
Old 02-17-2013, 08:33 PM   #57 (permalink)
cardoc's Avatar
Unless it was overfilled, when the level shows high, it is generally a flow issue. You may want to have the cooling lines and trans cooler flushed when you do the pan drop. The trans cooler portion of the radiator can clog up and restrict flow which will cause a chain reaction back to the transmission.
I believe you may find a clogged sump screen since it acted up when warm and went away after it sat a bit.
SubarCharged
naysayers
Old 02-18-2013, 06:06 AM   #58 (permalink)
If the AT Oil Temp light is flashing, shouldn't there be a trouble code stored in the TCM that could help localize or identify the cause?
This thread might help identify the code, or codes. Many of the codes relate to open or shorted connections to solenoids, which could affect the way the transmission functions.
