1997 valve adjustment. - Subaru Outback - Subaru Outback Forums
LinkBack Thread Tools Rating: Thread Rating: 8 votes, 4.00 average.
post #1 of 7 (permalink) Old 06-16-2008, 10:57 AM Thread Starter
I need to adjust my valves BADLY, and endwrench keeps "Server not found"'ing me.
I'm also striking out searching here this morning for some reason.
is my 97 the bolt and screw style adjuster or shim bucket?
is there a good writeup here somewhere for whichever style i have?
thanks,
nate
http://www.boogerwelds.com
sceep is offline
post #2 of 7 (permalink) Old 06-16-2008, 11:44 AM
Car: 98 OBL 280K miles
2.5L is shim/bucket.
BobN is offline
post #3 of 7 (permalink) Old 06-16-2008, 11:50 AM Thread Starter
thanks,
any idea where i can buy the adjustment tool required to do this?
sceep is offline
post #4 of 7 (permalink) Old 06-16-2008, 12:36 PM
I don't know about any special adjustment tool. I used a feeler gauge to measure the clearance and calculated the size shim I needed to replace the original in order to get proper clearance.
BobN is offline
post #5 of 7 (permalink) Old 06-16-2008, 12:38 PM Thread Starter
i've read here that the job cant be done without this tool
http://subaru.spx.com/detail.asp?partid=498187100
is that innacurate??
i have a well stocked shop and would prefer to not buy a tool, but i dont have time to tear it apart to find out. just to be down for a few days while i locate the tool.
thanks,
Nate
sceep is offline
post #6 of 7 (permalink) Old 06-16-2008, 02:40 PM
I guess that tool is required if you are doing the job in-place without removing the cams. It depresses the valve enough to remove the shim. I did mine as part of a valve job with the heads off, so it was easy to measure, then remove the cams and replace shims, then install cams and re-check. If your timing belt and cam sprockets are all still on, the special tool is easier than removing/replacing all that stuff.
BobN is offline
post #7 of 7 (permalink) Old 06-17-2008, 04:06 PM
Car: 2001 OB 2.5L Basic
I was just wondering if in fact it was neccessary to exchange any shims and if you knew the history of this particular vehicle in relation to earlier valve adjustments or inspection....
Petersubaru is offline
