Brake and Battery lights came on at the same time - Subaru Outback - Subaru Outback Forums
post #1 of 13 (permalink) Old 12-04-2008, 09:03 AM Thread Starter
mckeand13's Avatar
Car: 2001 Outback 2.5L Wagon
Question Brake and Battery lights came on at the same time
2001 OBW 2.5L Auto
This morning (10degF) I started my car and noticed that both the BRAKE and BATTERY lights were on. I stopped the car and then restarted but they both are still on. I popped the hood and checked all belts. Everything looks good. I can't check battery voltage until lunch today.
Why both at once? It seems like others have had this problem as the same question came up on a google search with no answers.
Thanks.
It's only weird because it's not normal.
mckeand13 is offline
post #2 of 13 (permalink) Old 12-04-2008, 12:11 PM
Bimmer's Avatar
Guessing here...
If one of the dual filament brake/taillight bulb goes bad, then it crosses the circuits and they both come on together.
Check your bulbs carefully.
Bimmer is offline
post #3 of 13 (permalink) Old 12-04-2008, 01:09 PM Thread Starter
mckeand13's Avatar
Ok, just checked a few things.
All bulbs present and working correctly.
All belts present and turning accessory.
Now for the culprit:
Checked voltage with car off. 12.2V. Good so far. Start the engine and it drops to 11.7V. No good.
So, what to check first. Is it possible to check the alternator output? Is there an external voltage regulator or is it built into the alternator?
Looking for suggestions on what to check first. I don't want to just throw an alternator at it hoping it's the solution.
Why is the brake light on? Does the ABS not have a high enough voltage to work or something like that?
Thanks.
post #4 of 13 (permalink) Old 12-04-2008, 02:11 PM
mslatfly's Avatar
Car: Current Car2016 Outback Premium in Wilderness Green. Former Car, 2008 Subaru Outback 2.5i Basic
Send a message via AIM to mslatfly
Thanks.
With the engine running, you should have around 14 volts. If you only have 11.7v with the engine running, you have either a bad connection, or a bad alternator. I believe the regulator is internal to the alternator. If you take the car to a shop, they can test the charging system (but, do they know what they are doing?).
When you say brake light, do you mean the brake lights in the back of the car, the brake light on the dash, or the ABS light? If it's the brake light on the dash, it could be the brake reservoir is low, or you have a brake pressure issue, or a bad switch on the hand brake. An ABS fault will not turn on the brake light, just the ABS light.
mslatfly is offline
post #5 of 13 (permalink) Old 12-04-2008, 02:57 PM Thread Starter
mckeand13's Avatar
The brake light as I mentioned, is the brake light in the instrument cluster, which would typically come on when the e-brake is applied. If I pull the e-brake, it actually makes the brake light a bit brighter.
The brake fluid is at the correct level.
I'm going to pull the alternator and bring it in to have it tested.
post #6 of 13 (permalink) Old 12-04-2008, 10:24 PM
Re: Brake and Battery lights came on at the same time
2001 OBW 2.5L Auto
Thanks.
Bad altenator/battery or both.
Have the chargning system checked.
nipper
nipper is offline
post #7 of 13 (permalink) Old 12-05-2008, 09:37 AM
oclvframe's Avatar
Car: 01 LLBean OBW, 03 RubiconTJ 5MT, 05 330cic ZHP 6MT, 07 530XiT AT, 07 Odyssey Touring
It sounds like the alternator. When I drove my h-6 with no serpantine belt (see post about h-6 noises and leaks) my battery and brake lights were on.
-r
oclvframe is offline
post #8 of 13 (permalink) Old 01-30-2009, 01:09 PM Thread Starter
mckeand13's Avatar
Almost forgot to post my followup.
Had the alternator checked at a parts store. Dead.
New alternator installed and all is good.
Thanks for the help!
post #9 of 13 (permalink) Old 01-30-2009, 02:16 PM
oclvframe's Avatar
Great news! Sounds like an easy fix!
On another note....when I replace my alternator, I simply bought a new one. So, now I have the one that wasn't really dead, but had a limited amount of life left in it. What's the best thing to do with that? Is there some place that buys used alternators and re-works them to sell them as refurb or do I simply throw it away?
-r
post #10 of 13 (permalink) Old 01-30-2009, 02:20 PM
A rebuilder may buy the old one off you for what he charges people on a core charge.
nipper is offline
