| View Poll Results: What method would you use to change the clutch? | |||
| Remove the engine |
0 | 0% |
| Remove the transmission |
1 | 100.00% |
| Slide the engine forward and get at the clutch with the engine still in the car |
0 | 0% |
| None of the above. I'd.... |
0 | 0% |
| Voters: 1. You may not vote on this poll | |||
Which way would you go about changing the clutch?
A: Remove the engine B: Remove the transmission C: Slide the engine forward and get at the clutch between the engine and transmission D: Other method not listed Thanks. Please explain if you can. |
