Cold weather fuel leak - Subaru Outback - Subaru Outback Forums
post #1 of 14 (permalink) Old 12-16-2008, 11:48 AM Thread Starter
Car: 2003 Outback LTD
hello long time listener first time poster,
I'm sure this subject has been discussed ad nauseum, but my 2003 Outback limited leaks fuel on to the engine block in very cold weather. The leak is occuring on the short piece of hose on the passenger side of the vehicle between the fuel rail and intake manifold. I have e-mailed SOA and got a response to bring it in to a dealer. IMHO, Subaru should pay for this as this is clearly a design flaw after researching this online. I know the WRX has a TSB about this, but this same problem occurs in the outback also. Has anybody else experienced this issue? If you did, and got SOA involved, did they pay for repair? This is a very serious problem since raw gasoline dripping onto an engine near the hot exhaust manifold is a sure way to cause a fire. Attached are some pics:
mrburls is offline
post #2 of 14 (permalink) Old 12-16-2008, 12:24 PM
Re: Cold weather fuel leak
Just fix it and dont worry about who is going to pay for it. i think this is a non starter as its just a little peice of hose. Get it done and be safer for it, instead of driving a potential fire issue.
nipper
nipper is offline
post #3 of 14 (permalink) Old 12-16-2008, 01:11 PM
Car: 2012 Outback Wagon
I had the same problem on a 2000 that I had, short-term fix is to tighten the hose clamps.
pedaler8090 is offline
post #4 of 14 (permalink) Old 12-16-2008, 01:26 PM Thread Starter
I tried tightening the clamps, but the leak is still there. I think that the hose must be double ply and one ply constricts further than the other. I bring it to the dealership on Monday, and I am going to tell them to replace the hose and clamps. I have always had this problem in cold weather, I just thought the engine was running rich. I was pretty surprised to to see gasoline dripping from the fittings onto the block. Once it warms up, its fine. I am just dissapointed that this is a common problem with Subarus and there should be at the very least, a TSB about it. This is the only reason I got SOA involved, since I have heard its a common problem.
mrburls is offline
post #5 of 14 (permalink) Old 12-16-2008, 04:20 PM
obsolete's Avatar
Car: 2005 Outback H6 3.0 LL Bean
Crikey. Time to go check mine...
If the dealer just replaces the hose with like, though, what's the point?
obsolete is offline
post #6 of 14 (permalink) Old 12-16-2008, 04:31 PM Thread Starter
There was no TSB for the outback, but it has the exact same issue. In fact the hose pipe that are replaced on this TSB is the same one that leaks on my outback. (The short piece between fuel rail and intake manifold) I'm sure Subaru used the same supplier for fuel hose on the outback and WRX. They both have the same issue.
mrburls is offline
post #7 of 14 (permalink) Old 12-16-2008, 09:59 PM
Superb Moderator
bheinz57's Avatar
Car: MY12 WRX, MY07 FXT
I had the same raw fuel smell and the dealer said to tighten clamps on my own or pay for them to do it. I have a MY02 OBS and it was not within the TSB either.
I tightened the fuel clamps I could get to, and no smell anymore. And it has been like 5* F for highs lately.
Brian
bheinz57 is offline
post #8 of 14 (permalink) Old 12-17-2008, 08:41 AM Thread Starter
How did you get to the clamps under that bracket? It looks like you can maybe put an offset screwdriver to get at it. Hope the whole manifold doesn't have to come off...
mrburls is offline
post #9 of 14 (permalink) Old 01-07-2014, 10:40 PM
same problem happening now with my 02 obw.
I smelled strong odor of fuel in the cabin 2 days ago (very cold) and again today (very cold night) on startup and warmup. Day in between was warm and did not smell fuel. seems like similar problem to all above.
dropped at dealer today. service advisor said fuel lines being over 11 years old this can happen in severe cold weather. they said that cold weather affects fuel line near fuel rail but they will leave car outside overnight and they will see if it smells like fuel again in the cabin in the morning on startup.
hopefully a small/cheap fix!
SportsCarAdvisors is offline
post #10 of 14 (permalink) Old 01-07-2014, 10:47 PM
eagleeye's Avatar
Thumbs up
Hey you bumped a thread from 2008.
Here is a more modern thread. Although it is nice to know they had a TSB on imprezas / wrx. PLEASE REPORT HOW MUCH THE DEALER CHARGED. THIS IS MINOR ISSUE WHICH THEY SHOULD FIX IN 15 MINUTES.
Gas smell in cabin
eagleeye is online now
