Help! How to separate transmission from engine - Subaru Outback - Subaru Outback Forums
Old 12-21-2008, 06:32 PM   #1 (permalink)
Car: 2005 Outback XT
Send a message via AIM to nlitend1
Red face Help! How to separate transmission from engine
I'm replacing my clutch and i'm all the way to the point where i need to separate the transmission from the engine and it won't come apart!!!
I've taken out the four bolts AND removed the four nuts from the studs holding the engine to the transmission. I've also followed the Haynes manual to the letter and at this point it says...remove the transmission to engine mounting bolts and then move the transmission backwards and then down to remove it.
haha, yeah right. I've disconnected everything and as far as i can tell there is nothing holding the two together.
Any advice?! I've been pulling as hard as i can backward and also attempted to pound on the transmission (all be it gently in fear of cracking it).
I"m at a stopping point until i can get these two separated.
Please help!
nlitend1 is offline   Reply With Quote
Old 12-21-2008, 06:45 PM   #2 (permalink)
Is this the separation point? It sure looks like it to me.
Old 12-21-2008, 07:51 PM   #3 (permalink)
wurkenman's Avatar
Car: 1998 Legacy Outback, 2.5, auto, Green
Yes that is the separation point. On the drivers side there will be a little tab sticking up on the bell housing. Use a pry bar or large screw driver and pry on the tab and the engine block. The alignment pins on the trans and block are a tight fit and will need some persuasion. I just went through all of this myself pulling the engine for a head gasket replacement.
2007 Legacy 2.5i
2005 Legacy GT 328 AWHP at 19 PSI
1997 Harley Custom Electra Glide
1998 Outback
wurkenman is offline   Reply With Quote
Old 12-21-2008, 09:12 PM   #4 (permalink)
Scooby Noob
gavinl's Avatar
Car: 1997 OBS EJ22
When I was swapping my 2.2 AT motor, I had a hard time separating the bellhousing off the motor, took a lot of brute shaking of the cherry picker with the motor hung on it before the tranny broke loose.
1997 OBS "ScoobyStein"
gavinl is offline   Reply With Quote
Old 12-21-2008, 10:16 PM   #5 (permalink)
Have you unbolted that dogbone?
Old 12-22-2008, 12:27 AM   #6 (permalink)
brianjglas's Avatar
Car: 1999 Legacy Outback
Yes, listen to nipper (I did...). make sure you unbolt the dogbone, then like others have posted it takes a bit of crowbar/screwdriver work to get them separated. I think it took me 30-45 minutes to get them apart when I did it.
brianjglas is offline   Reply With Quote
Old 12-22-2008, 12:29 AM   #7 (permalink)
Thanks guys! Wurkenman's tip was just what i needed. Wow, are those studs long and you really have to pry on the transmission to get it loose and all the way off those studs.
Transmission is out and i'm just waiting on the new clips for the throw bearing that should be here tomorrow. I also want to get some brake cleaner to make sure the surfaces of the flywheel and pressure plate are perfectly clean.
Hopefully i'll get it back together on tuesday night or wednesday. Thanks again.
Old 12-22-2008, 12:36 AM   #8 (permalink)
Is the yellow or the blue "x" the "dogbone"? The blue x is already dissconected. The yellow x kind of got in the way while trying to maneuver the transmission down and back once the engine was separated. I might remove it for easier installation.
Old 12-22-2008, 05:26 AM   #9 (permalink)
Flying Cavalry
outbackredux's Avatar
Car: 1997 OBW 2.2L 5spd
Here's a tip. Use anti-sieze on all the contacts surfaces bell housing and such when you put it together. If you ever have to take it apart again you won't have this problem. I use anti-sieze on everything that doesn't require something eles.
outbackredux is offline   Reply With Quote
