outback won't start - Subaru Outback - Subaru Outback Forums
Old 01-19-2009, 06:47 PM   #1 (permalink)
Recruit
Car: 2003 Outback
Default outback won't start
My Daughters 03 outback had a dead battery( interior lights left on) after charging the battery theh car won't start. No power, no lights , nothing. I cycled the door locks with the remote and still nothing. Also the car won't come out of park, I pressed the shift lock release and put it in neutral and still nothing. Any help would be much appreciated
Sam
dacaoch1428 is offline   Reply With Quote Quick reply to this message
Old 01-19-2009, 06:52 PM   #2 (permalink)
matty's Avatar
Car: 2006 OBW 2.5i 5speed, 2013 2.5i Premium
check the connections on the battery to make sure they are tight, corrosion free etc. Have you tried a different battery? Sounds like the current one may be toast.
Matty
2013 Outback 2.5i Premium
"What ain't no country I ever heard of. They speak English in What?"
matty is offline   Reply With Quote Quick reply to this message
Old 01-19-2009, 06:54 PM   #3 (permalink)
rockhopjohn's Avatar
Try double checking your battery connection, some times you can get enough of a connection for things like the door locks to work, but not enough of to start the car.
Are you sure the battery is still good? Might not hurt to have it tested, if it is the original battery, then go ahead and replace it, because its definitely overdue. You might also check your fuse box, make sure you didn't somehow blow an ignition fuse or something along those lines.
rockhopjohn is offline   Reply With Quote Quick reply to this message
Old 01-19-2009, 07:00 PM   #4 (permalink)
Battery is 6ish years old, it is prbbly time for a new one.
nipper
nipper is offline   Reply With Quote Quick reply to this message
Old 01-19-2009, 08:31 PM   #5 (permalink)
Recruit
Car: 2003 Outback
Got it. the fusible link had fried. $2.99 and 5 minute fix.
Thanks for quick replies. I look forward to being a part of this forum.
Sam
Old 01-19-2009, 08:34 PM   #6 (permalink)
Sam
hrmmm thats not a common thing to blow ...unless
someone crossed some wires someplace.
nipper
Old 01-20-2009, 09:44 AM   #7 (permalink)
Recruit
Car: 2003 Outback
nope no wires crossed. Turned the car off late saturday night and it wasn't touched until Monday morning. Found out last night that Iwent to school with the local Suburu service tech and gave him a call. After catching up a little bit he said sounds like the fusible link. I went out in the snow and checked with a test light and sure enough it was blown. He said he had seen it before with a badly discharged battery.
I charged the battery and had it checked last night, everything checked out good. Picked up new fuse and it started like a dream last night and this morning.
Thanks,
Sam
Old 01-20-2009, 02:29 PM   #8 (permalink)
Formerly Captain Asshat
RavenTBK's Avatar
Car: 2006 Legacy Outback Wagon
Heh, from reading your original post for the first time just now, the underhood fuses/links were my first thought. Seeing further down the thread shows you ended up with the same conclusion.
Glad you got it worked out so quickly.
1984 Subaru Brat GL - 6" lift, 30x9.50 tyres, desert camo paint, 430 watts out the stock headlamps, 100A GM large case alt conversion
2006 Subaru Outback Wagon 2.5i - mostly stock
RavenTBK is offline   Reply With Quote Quick reply to this message
Old 02-08-2010, 11:20 AM   #9 (permalink)
mamurao's Avatar
Car: 1998 subaru outback 2.5, 2 tone green on grey
Send a message via Yahoo to mamurao
Hi , i'am having issues with my outback not starting as well. you mention fusible link, can you advice where is that located?
my battery is 3 yrs old and last time the alternator was checked was when the battery was replaced and came back good.
thanks in advance
Theman
mamurao is offline   Reply With Quote Quick reply to this message
Old 02-08-2010, 05:53 PM   #10 (permalink)
miker104's Avatar
Car: 1999 30th Anniversary Legacy 2.5L 4EAT
Should be in the fuse box in the engine compartment (driver's side) near the windshield washer fluid container. Its a black wire that runs between two terminals.
Here's a photo I borrowed from another thread.
miker104 is offline   Reply With Quote Quick reply to this message
