Very cold, NO BRAKES - Page 3 - Subaru Outback - Subaru Outback Forums
Old 11-28-2012, 02:25 PM   #21 (permalink)
Originally Posted by ring-tailed-lemur View Post
OK, thank you!! Good to know. I will check that out and do the WD-40 thing. Give me a couple/few weeks and I'll report back with results.
Regarding the bit about "should be good for a while until you get significant water in there again", is there something else wrong given that water gets in there AT ALL? Or does that just happen with the Outbacks? Is there anything I can do to prevent water from getting in there again?
Brake fluid absorbs water ie moisture over time it needs to get flushed to get rid of the contaminated fluid every so many miles pending your location conditions etc.
Old 11-28-2012, 03:38 PM   #22 (permalink)
Car: 2005 XT Limited
The water isn't in the brake fluid, it's in the vacuum hose for power assist. It's not clear to me how it gets in there, but these are pretty high mileage cars.
tdelker is offline   Reply With Quote
Old 11-28-2012, 03:44 PM   #23 (permalink)
i guess when a car is turned off, the entire vacuum system could suck in atmospheric air. Then, certain temp/humidity conditions might cause some condensation in the vacuum lines.
Old 11-28-2012, 05:08 PM   #24 (permalink)
Car: 2003 LLBean H6 Outback
This happened to me only once, it seems to be a definite temp/humidity combo that creates it.
If someone is seeing it regularly an interesting diagnostic would be to shut the car off then pump the brakes to drain the vacuum, then see if the problem occurs in the morning.
CNY_Dave is online now   Reply With Quote
Old 11-28-2012, 05:26 PM   #25 (permalink)
I finally had to replace my brake booster and it solved the problem.
Old 11-28-2012, 06:48 PM   #26 (permalink)
cardoc's Avatar
Its really simple. Iced check valve will not allow vacuum on the booster which equals hard pedal due to not having any assist from the booster. After the engine warms up, the heat generated by the engine melts the ice in the check valve and allows the engine to pull a vacuum on the booster easing the pedal effort.
Water in the brake system can cause high pressure on the brakes. Especially at negative F temps. With the heater running in the car, it would assist in thawing some of the lines. Its more likely a brake booster issue or a frozen check valve. If the car has a check valve. Some don't.
If there is a tear in the booster diaphram, it can pull in moisture.
Old 11-28-2012, 09:14 PM   #27 (permalink)
Cardoc, I have only the one case to test against, but it seemed as though it cleared itself much faster than engine warming could explain.
BTW, received those 2 items, I still gotta get the shipping to you somehow...
Old 11-28-2012, 09:18 PM   #28 (permalink)
cardoc's Avatar
Don't sweat it. I'm not. I don't need it. As long as it worked for you that's all that matters.
Old 11-28-2012, 11:07 PM   #29 (permalink)
DAS
Car: 2002 L.L. Bean Outback H6 3.0
I saw that you're also in VT, so it's at least good news that you still have the car. I was slightly worried you were going to reply with, "Nope, we sold the car this past summer in Montpelier, and it was white with 55k".
I drive through Montpelier every day. The intersection I spoke of is where rt 14 hits rt 2 in east Montpelier. Small world. BTW the brakes were fine today...
DAS is offline   Reply With Quote
Old 11-29-2012, 07:44 AM   #30 (permalink)
Why is no one replacing the check valve?
