2001 Air Conditioning problem - Subaru Outback - Subaru Outback Forums
post #1 of 7 (permalink) Old 03-08-2009, 07:24 PM
elanghout
Guest
Posts: n/a
I have a 2001 Outback 2.5L and have been having problems with my air conditioning working at all times. When we have the air conditioner button pressed in on the consol, sometimes the compressor will engage and sometimes it will not. Lately, it has not been engaged more often. I have bypassed the switch by connecting a wire from the compressor to the battery to ensure the compressor still works and it did. It seems like there is a short from the ac button switch to the compressor. The light on switch does come on whether the compressor comes on or not. We checked the refrigerant level and it was at the required mark. I was thinking I might need to get behind the ac switch in the consol to analyze the problem. Has anyone had this problem before? Thanks
post #2 of 7 (permalink) Old 06-11-2009, 11:51 PM
Car: my200 Outback, 2.5 litre sohc with the typical problems...
Probably way late for a reply but likely it's the A/C relay... hopefully you have it fixed by now, what was it?
gasgasrider is offline
post #3 of 7 (permalink) Old 06-12-2009, 10:03 AM
I :heart: SUBARU
porcupine73's Avatar
Car: '00OBW, '96&'94 Legacy
Another thing in the circuit is the pressure switch. Haven't seen too many posts about those going flaky but it is another thing that could make the compressor not engage. There is also a relay for the ECU to cut out the a/c at full throttle maybe that is flaky.
porcupine73 is offline
post #4 of 7 (permalink) Old 07-05-2014, 08:13 PM
I know this is an ancient post but I have the exact same problem and was wondering if anyone has any more input.
Thanks.
rybot is offline
post #5 of 7 (permalink) Old 07-06-2014, 02:48 AM
Zedhead's Avatar
Car: 08 Outback LL Bean 2.5- 00 Outback Ltd.- 98 Outback
You need to get a AC test gauge set and check your pressures. More than likely there's a small leak somewhere, and the pressure is low.
'08 OB LL Bean 2.5
'04 Foz XS
'00 OBW LTD
'98 OB
Driving with no eyesight system. Not dead yet!
Zedhead is offline
post #6 of 7 (permalink) Old 07-06-2014, 02:54 AM
cdc
Thanks.
Many things can make a compressor not come one, a leak would be the most common reason, but electrical problems, pressure problems, and mechanical problems can also be the cause. Why don't you describe the problem you are having yourself. Do you have a volt meter? Are you comfortable diagnosing electrical circuits? Do you have access to A.C. gauges to read the pressures in your system?
cdc is offline
post #7 of 7 (permalink) Old 07-07-2014, 10:15 AM
Thanks.
more than likely low refrigerant. if system pressures aren't correct the system won't turn on, or will shut itself off.
need to check refrigerant pressure.
DIY A/C Air Conditioning leak refrigerant repair for $5 or less/15 minutes or less
but of course other things can cause it.
grossgary is online now
