Rattling Noise from Right Rear - Subaru Outback - Subaru Outback Forums
post #1 of 7 (permalink) Old 05-06-2009, 09:18 PM Thread Starter
My new (78k miles) '05 Outback likes to make this rattling noise from the right rear after the wheel springs back after going over a bump in the road. The suspension is very tight and feels okay. It doesn't feel like a clunk; more like a "prrr".
I am thinking it could be a stabilizer bracket or bushing. Any ideas how to troubleshoot this systematically?
feuser is offline
post #2 of 7 (permalink) Old 05-07-2009, 05:46 AM
ETC
ETC's Avatar
Car: 00 OB 07 OBXT
you can try to stand on the rear bumper and get the suspension to cycle and see if you can recreate the noise.
does it sound like a suspension rebound thing or a rotational thing like a cv ?
make sure the strut isn't leaking, that the spring looks seated properly.
check all the linkage bushings are intact, and check the left side against the right to see if anything looks "off"
if you can have a local parking lot with a speed bump, maybe you can have someone drive past you while you're next to it to see if you can get a better idea of what's making the noise.
ETC is offline
post #3 of 7 (permalink) Old 05-07-2009, 08:43 AM Thread Starter
It DOES sound like a suspension rebound noise.
Standing on the rear bumper (and leaping off) yields nothing but quiet. The suspension seems okay albeit somewhat too stiff for the wagon without cargo. The Bridgestone 009 don't help but it feels skittish. I felt that there was a lot of weight transfer going on in corners for a suspension this tight, but then, I am coming from a lower 98 GT Wagon with mushy suspension.
I guess the sound COULD originate from loose trim, body panels. Nothing obvious so far. I will try closing a towel into the rear door. Is there a way to tighten the roof spoiler or is it attached with clips only?
feuser is offline
post #4 of 7 (permalink) Old 05-07-2009, 10:59 AM
ron917's Avatar
Car: 07 2.5i
My rear license plate is attached with only two screws at the top. When I close the hatch, the plate vibrates against the hatch making a rattly sound. Sometimes I hear the exact same sound after hitting a bump, so I'm guessing the plate is vibrating while driving (but I can't see the plate bounce while I drive). Just another possibility for you to check.
ron917 is offline
post #5 of 7 (permalink) Old 05-07-2009, 11:06 AM
rockhopjohn's Avatar
Mod Note: I deleted your other thread in the new user forum, and updated the title of this one. This is the correct forum.
rockhopjohn is offline
post #6 of 7 (permalink) Old 05-07-2009, 01:12 PM Thread Starter
Plate is attached with 4 bolts. No wobble here.
I also closed the hatch with two pieces of neoprene rubber wedged in next to the tail lights (See thread Rattle in rear of '06 OBW XT)
No joy yet; next i'll try and drive with the tail gate open and see what happens (except my stuff falling out)
feuser is offline
post #7 of 7 (permalink) Old 06-20-2009, 09:33 AM
Car: 2015 3.6Rrrrr
buzzbuzz = feuser.
The new alias is courtesy of my little son naming our Outback after a few rides in the OB.
The rattle however is gone.
I had a set of KYB shocks/struts with new top mounts front (OEM) and rear (KYB) put into the car. At the same time, the front sway bar bushings were replaced and a pair of new end links (front) installed.
The car is quiet over bumps now and feels much more attached to the road. The rear wheels would pogo after going over a recessed manhole cover and hitting the brakes on uneven surfaces would cause the ABS to activate. I have never felt the ABS kick in in my old 98 wagon except on ice or sometimes wet and slick roads.
I could not drive the car between installs, but I am fairly certain that there were two separate noise sources: the sway bar bushings and the strut mounts.
The former are easy to replace in DIY, the latter should be done when replacing the stock struts.
FWIW: It took several attempts to get the right part for front strut mounts from online stores and dealers. Maybe bad luck. Here are the part numbers:
20320AG00A = B13 Legacy/Outback MY 05+ USA
20320AG000 = B13 Legacy/Outback MY 04+ Europe
20320AA100 = B12 Legacy/Outback MY 00-04 USA
BuzzBuzz is offline
