hot metal smell under hood - Subaru Outback - Subaru Outback Forums
post #1 of 6 (permalink) Old 06-22-2009, 01:08 PM Thread Starter
Car: 1999 Outback Limited 2.5L
I recently got my hands on a 1999 Outback limited. After some driving there seems to be a hot metal scent from under the hood. The car does not run hot and the fluids seem pretty stable. It goes away quickly, but I was just wondering if anyone has had any experience with any such problems. Thank you
zmanjohns is offline
post #2 of 6 (permalink) Old 06-22-2009, 02:13 PM
Car: 97 OBW
Might have oil leaking onto the exhaust and burning off before it can hit the ground.. even a minor oil leak can cause the smell. Could be from engine or transmission, my 97 had a small leak from the transmission output shaft occasionally dripping onto the exhaust.
rsarver is offline
post #3 of 6 (permalink) Old 06-22-2009, 06:56 PM Thread Starter
thanks
thanks for the input/info. Is there a good way to check for this and is it a big deal in the long run? worth try to fix? the car has a good amount of miles on it (160k). thanks
post #4 of 6 (permalink) Old 06-23-2009, 07:01 PM
Car: 97 OBW
Leaks are not usually a good thing, depends on the severity I suppose.
Poke your head underneath with a flashlight, engine oil leaking onto the exhaust should be visible from the front of the car. If it's the transmission output shaft seal, might be trickier to see but will be visible under the middle of the car. Mine was dripping occasionally onto the heat shield, discoloration on the heat shield under the transmission was a good clue.
rsarver is offline
post #5 of 6 (permalink) Old 06-23-2009, 10:26 PM
wurkenman's Avatar
Car: 1998 Legacy Outback, 2.5, auto, Green
Check for a torn CV axle boot. This will cause the grease to get slung up on the exhaust and make a real terrible smell.
2007 Legacy 2.5i
2005 Legacy GT 328 AWHP at 19 PSI
1997 Harley Custom Electra Glide
1998 Outback
wurkenman is offline
post #6 of 6 (permalink) Old 06-24-2009, 12:50 PM Thread Starter
cv axle boot
I think I might have a tiny whole on the inner cv axle boot on my passenger side. it is on the long skinny rubber boot towards the center of the undercarriage. How much is that to get fixed at the garrage and how hard would it be to do myself if I bought the part somewhere?
if it helps at all I can try to take a picture of the issue
