Hey guy I am new here and was wondering if you all could help me out. i bought a 2000 subaru outback limited 4 cyl with 146000 miles on it. the gal i bought it from owned it for about half year and the guy she bought it from had it for 13 years. I got the car cheap because she had check engine light on but now i am not sure if it was the right move.
I have 6 Codes that came up
-P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance
-P0172 System too rich (bank 1)
-P0172 System too rich (bank 1) for some reason it gave the code 2 times not sure why
-P0304 Cylinder 4 misfire detected
-P0302 Cylinder 2 misfire detected
-P0301 Cylinder 1 misfire detected
SO i checked the oil and there was too much maybe about 2 quarts overfull and i checked transmission fluid same thing. so i drained both and basically filled it back up to the proper level and same codes
I ALSO HAVE SMOKE COMING OUT OF THE BACK. When the engine is cold there is a cloud of somke coming from the back it looks blue first than white and eventually gray i think or either white and blue.
SO i fill up the car with fuel and it sitting there running will in like couple hours take the fuel level from half to a quarter its crazy.
SO when car warms up there is that smell of smoke but no smoke visible.
I hope you all can help. thanks.
