Car: 2005 Subaru Outback 2.5i 2.5 L non-turbo
I have an intermittent problem with the steering, I think only when parking (we park parallel in front of our house) but not necessarily when sitting still, sometimes rolling still. The wheel will lock up (can't turn it at all) and the belt squeaks like the power steering pump stopped spinning. Then everything is back to normal. It lasts for a second, sometimes it does it a couple of times in one parking maneuver, sometimes only once. It does it when the car is cold or hot, sometimes when we're pulling away from the house, sometimes when returning to the house. Summer or winter, but perhaps more in winter. It's been a lot less frequent lately. It is not turned to full lock but I think it's only when making a rapid steering change (like you do when parallel parking).
Any thoughts? |
Car: 05' OB 2.5i
Check for a worn belt. Mine was squeaking on takeoff when cold. It wasn't squeaking when turning oddly enough.
I looked at the belt and it was badly cracked probably original. Replaced it and did 3 drive/tension adjustment cycles to make sure it was just tight enough not to squeak. The tension adjuster is variable so the tightness can be adjusted unlike preset tensioners. Your situation is the pump causing extra load on the belt and the belt slipping over the pulley due to being loose or worn. This causes 0 power steering pressure. I imagine that quick movements would cause spikes in load just like turning it and hold it at left lock or right lock. If you need pictures or instructions let me know.
#4 (permalink) | |
Car: 07 OB 2.5i Basic 120,000+ Miles
Check out this thread where I posted an answer to this issue.
Belt Noise |
