Hesitation and backfires - Subaru Outback - Subaru Outback Forums
post #1 of 15 (permalink) Old 10-30-2009, 07:47 PM Thread Starter
Car: 2001 Subaru Outback
Hello all,
I have a 2001 Outback 2.5 AT. The car has 82,000 miles and recently started hesitating while accelerating from a stop. It occasionally backfires. I’ve searched this forum and just ordered a front oxygen sensor from subarupartsforyou.com. I haven’t received it yet, but i have been doing a little bit more research and am starting to wonder if it is the 02 sensor or not. The car now hesitates on acceleration and at about 3,000 to 4,000 rpm. Anyone have any ideas on what this might be?
paweliania is offline
post #2 of 15 (permalink) Old 10-30-2009, 08:53 PM
Snowcase's Avatar
Car: 98 Legacy Outback Limited
Mine had a very similar problem but I wouldn't call it backfiring. It was the front o2 sensor. Had 3 mechanics look at it (all of which I told to look at the o2 sensor) and none of them could figure it out. $120 and 2 hours of work later it's worked perfectly for a year now.
Do you love winter sports and are a photographer or filmer?
Snowcase is offline
post #3 of 15 (permalink) Old 10-30-2009, 10:42 PM
Could be an O2 sensor or a knock sensor.
As an FYI you will be coming up on a timing belt very shortly, every 106,000 miles OR 106 months, which is 8-9 years.
Its a bit early for an O2 sensor but it happens. A tuneup may be a good idea too.
nipper
nipper is offline
post #4 of 15 (permalink) Old 10-30-2009, 10:51 PM Thread Starter
Thanks for the replies. The weird thing is that the check engine light has not come on.
post #5 of 15 (permalink) Old 10-30-2009, 10:57 PM
Not really odd, but still have the codes read, as there may be a code stored.
BTW the CEL does work?
nipper
nipper is offline
post #6 of 15 (permalink) Old 10-31-2009, 12:35 PM Thread Starter
Yea the CEL does work. I pulled the codes yesterday and the only thing that was on there was P0302 which is cylinder 2 misfiring. But that was because I was stuck in snow the other day, and was going drive then reverse to try to get out, that is when the check engine light went on. It was not on before that. Since then I reset the CEL and it is not comming on again.
post #7 of 15 (permalink) Old 10-31-2009, 02:21 PM
So lets replace the spark plug wires with OE then.
nipper
nipper is offline
post #8 of 15 (permalink) Old 11-01-2009, 10:45 AM
Snowcase's Avatar
I had the same code. I replaced the spark plugs and reset it. I can't recall if it ever came back before I replaced the o2 sensor but since the sensor I have had one CEL and it was a p0420. Cleared it and it hasn't come back in months.
Snowcase is offline
post #9 of 15 (permalink) Old 11-01-2009, 07:36 PM
highest_vision's Avatar
Car: 02 Outback 2.5 5sp
What kind of fuel pressure do you have? Miles on fuel filter? When you say 'hesitates ... at about 3,000 to 4,000 rpm,' do you mean only in that rpm range or from that rpm point onward, you have lost power?
James
highest_vision is offline
post #10 of 15 (permalink) Old 11-01-2009, 08:05 PM
Car: 1997 and 1999 Outbacks, 2.5L
The replies to your problem are generally pointing to a complete, major tune-up of your vehicle. The misfire in one of your cylinders should be fixed soon.
TheFixer253 is offline
