in
this forum
in
the entire site
Advanced Search
Cancel
Login / Join
What's New
Forum Listing
Products
Marketplace
Showcase
Gallery
Advanced Search
Members
FAQ
Dark Mode
Light Mode
menu
Log in
Sign up
Home
Forums
Technical forums
Problems & DIY Maintenance
Follow Forum
Create Thread
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
Do-It-Yourself Illustrated Guides
10.7K
17.5M
3d ago
10.7K
17.5M
3d ago
All Around Glass - Windshields, Sunroof, etc...
Love or have a disdain for your OEM or aftermarket glass on your wagon. Share your experiences from beginning to end if you've found a resolution.
881
1.3M
Mar 10, 2024
881
1.3M
Mar 10, 2024
Filters
Show:
Loading…
1
1 of 695
Go to page
Go
695
Sticky
FB25B and FB20 Extended Warranty, Oil Consumption
eagleeye
May 15, 2018
10
20K
4d ago
by
YeuEmMaiMai
S
Sticky
CVT Warranty Extension 2010-15
SamSpade
Jul 1, 2017
23
24
25
494
275K
Mar 11, 2024
by
tramfan
Sticky
P0420 Diagnosis
cardoc
Oct 31, 2012
147
148
149
3K
996K
Mar 3, 2024
by
bluehawk91
F
Sticky
Which OBD app for Apple iphone / Mac ?
flyingfool
Dec 25, 2019
2
22
19K
Feb 15, 2024
by
tpet
Sticky
Rust Proofing: Annual Oil Based Fluid Film, Pro / DIY Ideas
Brucey
Jul 30, 2018
6
7
8
155
53K
Feb 4, 2024
by
Toad442
Z
Sticky
Which OBD2 scan tool and android software
zehyani
Feb 8, 2017
2
3
4
72
91K
Oct 13, 2023
by
nutdriver
Sticky
Basic noise-diagnostic questions
The_Lizard
Mar 12, 2009
14
15
16
318
175K
Feb 2, 2023
by
Green2015Outback
S
Sticky
Vibration at Idle After Replacing Front Axles? Solved.
SgtSchultz
Jul 24, 2011
11
12
13
256
217K
Dec 17, 2021
by
1 Lucky Texan
S
Sticky
P0303 and P0304 codes
seanlivolsi
Sep 6, 2015
4
5
6
115
76K
Mar 26, 2020
by
YeuEmMaiMai
Sticky
"Check Engine" ODB-II / ODB2 Code Reference
JazzyMT
May 10, 2006
Locked
1
79K
May 10, 2006
by
JazzyMT
Gen 3
Sport shift in 2004 Legacy GT 2.5 EJ251
James Rinehart
31m ago
0
6
31m ago
by
James Rinehart
S
Oil leak from timing cover
sspeed
Mar 1, 2011
12
61K
53m ago
by
Necino
K
Cruise control cancels itself!
KimC
Dec 11, 2020
7
3K
1h ago
by
terry.arnott.au
Gen 3
Running Hot, Wondering Why
TakamaPark
4h ago
2
82
2h ago
by
TakamaPark
Gen 5
2017 Outback 3.6r overheating in idle
Sjr42689
2d ago
5
196
7h ago
by
Sjr42689
T
Gen 6
Battery change out/auto tail gate reset/seat belt warning sound/tail gate access code
Tazaandona
10h ago
1
80
7h ago
by
hallux
Gen 4
Clunking noise from front suspension
Achim
Jul 4, 2023
16
3K
8h ago
by
crazyroscoe54`
Other:
2019 outback microphone not working
Meremirkin
Jun 4, 2023
23
4K
8h ago
by
2019OutbackCali
O
Gen 4
Should this serpentine belt be replaced immediately? (2014 Subaru Outback with 49k).
outback2333
14h ago
5
271
12h ago
by
YeuEmMaiMai
B
Gen 2
2002 LL Bean Trans fluid/filter change woes.
Ballistixx
Feb 17, 2024
6
245
13h ago
by
Usmc1968
F
Gen 4
All cylinders detect misfire - Timing Belt Replaced
fmrRay
1d ago
2
126
14h ago
by
fmrRay
Gen 5
Random Humming While Driving
zackbedee
2d ago
4
166
14h ago
by
zackbedee
N
Confusing errors on dash (AUS)
NTJack01
22h ago
1
223
19h ago
by
cardoc
Gen 4
2011 Outback Rear Hatch Fob Behavior
bobk25
2d ago
4
117
23h ago
by
bobk25
Gen 3
LH side back and front Speed Sensor errors
yzenezy
2d ago
5
153
1d ago
by
plain OM
W
Gen 3
2008 Outback, P0500 code, replacing VSS
Waynehill
1d ago
0
30
1d ago
by
Waynehill
F
Gen 7
2021 Outback RAB Warning on Screen Then all warning lights go on
foshrob
1d ago
0
61
1d ago
by
foshrob
Gen 3
Coolant leak
Dillon7
2d ago
4
157
2d ago
by
Yourfavoritesubaru
F
Gen 4
I screwed up!
FrankSpence1967
2d ago
1
107
2d ago
by
seagrass
Gen 6
2020 Onyx XT 60,000 service
stubrru
2d ago
0
127
2d ago
by
stubrru
V
Gen 3
AVLS heads going on to 251 block and then into a non-AVLS 253 ‘05 outback
VirginiaEJ25Collector79
3d ago
3
127
2d ago
by
cardoc
L
Gen 5
Hatch not opening when car is running
LLucas
May 26, 2022
10
1K
3d ago
by
erndog66
A
Gen 1
Fix My Outback Without Too Much necessary $$$
AntiSpin
4d ago
4
122
3d ago
by
Wiscoutback87
S
Need to replace gear shifter light on 2005 Outback
sumdumgai
Apr 13, 2012
28
59K
3d ago
by
nam20485
B
Gen 4
Subaru Outback 2010 2,5l petrol. Xenon headlight issue
Bondeboogie
4d ago
2
141
4d ago
by
YeuEmMaiMai
A
Cylinder 1 and 2 misfiring
akelelias
Jun 28, 2010
20
61K
4d ago
by
justinrabito2
Gen 3
Outback Rattle/Thunk from passenger rear quarterpanel...
AJeiFoyt
Feb 27, 2024
20
541
4d ago
by
AJeiFoyt
A
Gen 4
What's wrong with this picture? Yes, I still have the beast. It recently had an overheating issue
allypurp@gmail.com
Feb 23, 2024
27
788
4d ago
by
allypurp@gmail.com
Gen 6
Paddle shifters question >>>
SubyNuby
6d ago
8
340
5d ago
by
SubiJeffrey
J
Gen 5
Infotainment/Headunit Hell
joseph.sadove
5d ago
1
88
5d ago
by
DAW89446
H
Gen 4
Blown Motor Help
Hectorlancer
6d ago
6
201
5d ago
by
Hectorlancer
A
Gen 6
Dashboard Rattle Noise: Subaru Outback 2022 around 40 mph (Video attached)
antiqueoutback
Dec 15, 2022
10
4K
5d ago
by
JCtx
K
Gen 5
VVT : P0021 and P011 error code on a 2015 2.5i
kdesrosiers
Mar 9, 2024
10
214
6d ago
by
kdesrosiers
CEL turned off.
mikekerstetter
Nov 24, 2010
11
2K
6d ago
by
geohagiograph
M
Gen 3
2005 whistling sound 1500rpm 20mph
M1k3yd
Mar 4, 2024
22
427
6d ago
by
7stars
1
1 of 695
Go to page
Go
695
220.8K
posts
148.2M
views
Discuss various problems and maintenance solutions you encounter. (Engine/Drivetrain/HG subforums)
Show Less
Join Community
Grow Your Business
Forum Staff
View All
AWDFTW
S
seagrass
johnre
Top Contributors this Month
View All
cardoc
SilverOnyx
bryancraftyhands
Recommended Communities
AVS Forum
1M+ members
Any & All Cooking Talk
130+ members
Solterra Forum
2K+ members
Home
Forums
Technical forums
