Loud Blower Motor? - Subaru Outback - Subaru Outback Forums
Old 02-25-2010, 10:07 AM   #1 (permalink)
Car: 2005 Outback H6 LLBean
Default Loud Blower Motor?
I have an '05 H6 LLBean, which I bought used a little over a year ago. It has always had a slightly-too-loud, and pretty annoying whirring sound from the blower motor. It tends to be worse on low fan speeds because I think it gets drowned out by air noise at higher speeds.
I pulled the motor/fan assy out and ran it on my workbench, and it seemed fine. Maybe there is a flow restriction that somehow contributes to the whirring noise?
I just wanted to float this question out there and see if anyone else has noticed this same thing in their OB.
"It's 30-minutes away . . . I'll be there in 10."
- The Wolf, Pulp Fiction
Pazu is offline   Reply With Quote
Old 02-25-2010, 11:44 AM   #2 (permalink)
superu's Avatar
Car: 2005 OBW 2.5i, snorkel, skid plates, etc...
My 05 started doing the same thing about two months ago. Drowns itself out a bit on higher speeds and is more noticeable on lower speeds.
05 Subaru Outback
03 Chevy Suburban
95 Audi S6
"99% of being smart is knowing what you're dumb at..."
The Superu
superu is offline   Reply With Quote
Old 02-26-2010, 04:44 AM   #3 (permalink)
ETC
ETC's Avatar
Car: 00 outback
Mine had a bunch of leaves in it when I got it and changed the filter out the first time. Might want to check the air inlet to see if there's anything in there.
Old 02-09-2011, 09:49 PM   #4 (permalink)
Car: 2005 H6 LL Bean Edition
Default Fan Motor Got louder tonight
What appear to be the fan motor on my 05 outback got noticably louder tonight on the way home. The sound appears to be coming from under the dash on the passenger side. Not a wind noise, but a whirring /whining sound as described on this thread. It goe up and down in pitch with the fan speed seetings. Is this pretty common? I have seen other posts outside this forum that indicated that the fan bearings get rusty from water leaks? Any merit there? Its not like it was getting gradually louder. It was normal fan sounds then all of a sudden you can hear a whine/whirring noise that was annoying. Is it easy to get at the fan? Any help is appreciated.
hotmillmet is offline   Reply With Quote
Old 02-09-2011, 10:31 PM   #5 (permalink)
Mine did it. It was just dirt and leaves.
Old 02-10-2011, 07:04 PM   #6 (permalink)
superu's Avatar
Mine developed the whining a while after I had discovered the carpet soaking annoyance that resulted from a clogged evaporator. I think in my case the noise is due to combined events of the motor bearings getting worn from trying to move water and from rust.
I'll be picking up a used replacement for $60 next week and will install it when I put the new carpet and seats in.
Will let you know if that resolves the noise issue.
05 Subaru Outback
03 Chevy Suburban
95 Audi S6
The Superu
Old 10-20-2011, 10:48 PM   #7 (permalink)
Did you have any luck resolving the noise? Was it the bearings going out?
wrxtremest is offline   Reply With Quote
Old 10-21-2011, 08:06 AM   #8 (permalink)
The dealer replaced the fan motor even though it was out of warranty at no charge and that fixed the issue. Talk to the service manager, he may opt to charge back to Subaru on item that really should not break. They are allowed so many charges per month back to the company on out of warranty issues I am told.
Old 10-21-2011, 08:41 PM   #9 (permalink)
superu's Avatar
The $60 used replacement worked perfectly! Super easy to do too!
05 Subaru Outback
03 Chevy Suburban
95 Audi S6
The Superu
Old 11-19-2012, 08:10 PM   #10 (permalink)
Car: 2005 Outback XT Limited (Black,Charcoal Leather)2.5 turbo-5 speed
Same issue in mine as well! '05 Outback XT Limited. Do you remove the Glove Box to access the fan???
Thanks guys and gals.
J.
jrolfs is offline   Reply With Quote
