How do you tighten the harmonic balancer bolt to the recomended 90-100 ftlbs on an automatic 1997 subaru legacy outback? The engine just spins when i try to tighten it, any suggestions?
Car: was a 2002 OBW 2.5L AWP
There's an inspection hole with a rubber plug in it that will let you get access to the flywheel so that you can jam a wrench or a screwdriver into it. It's near the throttle body on the passengers side.
FYI: Early 2002 Outbacks may have 2001 brakes. |
#4 (permalink) | |
Car: 07 2.5i
The inspection hole is pretty well hidden under wires and stuff, just push them out of the way a bit to find it. |
Breaker bar with socket, cheater pipe slipped onto breaker bar. Brace the bar/pipe against the ground, disconnect plug wires, LIGHTLY tap the starter. Ta-da!
