Fuel Pump Relay/Fuel Pressure Relief - Subaru Outback - Subaru Outback Forums
Old 05-26-2010, 01:57 AM   #1 (permalink)
Default Fuel Pump Relay/Fuel Pressure Relief
I know that in order to relieve fuel pressure, I have to disconnect the connector from the fuel pump relay. I also know that the fuel pump relay is located somewhere under the steering wheel.
What's the best way to get at it? Do I have to remove any dash panels?
domstriker is offline   Reply With Quote
Old 05-31-2010, 03:20 PM   #2 (permalink)
Car: 99 outback 4eat, 00 fozzy 5spd
Bump for a 99 outback
LanceDa is offline   Reply With Quote
Old 05-31-2010, 03:56 PM   #3 (permalink)
I can't directly answer your question, but if you leave the car parked overnight, fuel pressure should be next to nothing.
Otherwise, on my 97OBW, I would unscrew the access panel in the rear cargo area, unplug the fuel pump wiring harness, start the engine and let it run until it died (if it started at all).
RobLog is offline   Reply With Quote
