Hey Everyone,
I hope someone on here can help me ASAP. I have a huge problem with my car. Tonight I was out for a drive, when I returned I went to put my car into park as I normally do. I had my foot on the break, placed the car in park and shut the car off. I then removed my foot from the break and the car began rolling backwards, about a foot before I depressed the break again. According to the gear selector the car is in park but its not acting like it is. I am unable to start the car now, and I can not shift the car out of the position it is in. If anyone has any idea about how I can fix this or what may be wrong with it, I would greatly appreciate it. The car is a 1999 Subaru Outback with an automatic transmission. Thanks in advance |
Eiderman they make cars with something called a parking brake for a very good reason!
No transmission is designed to hold the car when in park. However they have small teeth called pawls which snap into a gear and provide a limited amount of friction to prevent rolling. These can be broken easily or worn out if a car is not parked with the parking brake correctly. May I strongly suggest you learn how to correctly use the "parking Brake" you engage it before releasing your foot brake and when releasing the parking brake you only do so after you have applied the foot brake. Try it your car will not roll. By the way I live in San Francisco where you get ticketed if you don't curb your tire and yes we get cars which break their parking pawls and run down streets or hit other parked cars quite often due to people ignoring the proper use and application of the "Parking Brake" |
Sounds as if the cable that connects the in-cabin gear selector lever to the inhibitor switch on the side of the transmission either slipped from its clamp mounts or broke just as you moved the lever to Park.
Gear selection in the AT is electronic (that's one of the roles of the inhibitor switch), but control of the parking pawl is mechanical -- the cable moves a lever at the inhibitor switch. The lever goes into the transmission where it is connected to the pawl. Moreover, the position of the inhibitor switch determines whether the car will start. It has to be in its Park or Neutral position. If the cable broke before the switch actually reached the Park position, it's either still at R, or somewhere in between in which case it "inhibits" the starter from functioning. It's not uncommon for the cable mounts or the cable itself to fail, especially due to rusting. This will require raising the car to inspect the cable. Probably need to flatbed the car to a garage, or where it can be serviced. Attached is a diagram of the gear selector linkage, showing the cable, and another showing the cable at the inhibitor switch. Let us know what you find. |
#4 (permalink) | |
#5 (permalink) | ||
Car: 1998 Outback 2.5l - Auto - Cold Weather Package
![]() Sounds like the cable broke. Can you still move the gear shifter? If not the shift lock might be stuck. Follow the procedure in the owners manual to over ride the shift lock. |
Redilyn
Good point on the shift lock involvement. Also, this problem could be caused by accumulated dirt or rust on the two linked levers at the inhibitor switch. It can prevent them from moving fully into the Park position, while the select lever itself does, and then the lever gets "trapped" in Park by the shift lock, which won't release it because the inhibitor switch isn't in the Park position. All to say, it's probably a shift linkage issue of some sort. If the override of the shift lock works, and the cable is, in fact, still good, moving the select lever back and forth a few times (P to 1) might clear up, the problem, at least temporarily. |
Car: 2011 Outback 3.6R Cyprus Green Metallic, No Nav or Moon Roof
subiesailor, This is my first Subaru and I have been driving for more years than I can remember. In all previous vehicles I ALWAYS used my parking brake just as you describe and never had a problem related to the parking brake/transmission interaction.
When I picked up my new 3.6 Outback the salesman told me not to use the parking brake unless on a very steep incline. Thanks to your comment and a re-reading of the owner's manual, today I start doing it the correct way again.
2011 Outback, 3.6 R Limited, Cyprus Green Metallic, trailer hitch, window rain guards, no navigation or moon roof, |
#8 (permalink) | |
