02 VDC Front Window washer not working - Subaru Outback - Subaru Outback Forums
post #1 of 5 (permalink) Old 12-04-2010, 09:37 AM Thread Starter
kinerf's Avatar
Car: 2002 Outback VDC H6 3.0l Black
Question 02 VDC Front Window washer not working
The front windshield washer was not working. Replaced the pump. Still no go. Changed the connector from rear to front. Pump works great. Is this a wiring problem or do I replace the multi-function control lever inside the car? All the other functions work fine. So basically I am using the rear sprayer control on the stock to spray the front window.
Hope that's not too confusing. Let me know.
kinerf is offline
post #2 of 5 (permalink) Old 12-04-2010, 10:46 AM
SovereignAxe's Avatar
Car: 2000 Green OBW (Maia)
I can't remember if they have separate fuses or not, but have you checked the fuse (if it is separate)?
SovereignAxe is offline
post #3 of 5 (permalink) Old 12-04-2010, 05:03 PM
Feedback Score: 7 reviews
Not confusing at all.
There's separate fuses in the in-cabin fuse box for the front and rear systems. Each fuse powers both the respective washer motor and wiper motor. So if the front wipers and rear wipers work, both fuses are good.
The power for the front washer essentially goes from the fuse to one pin of the washer motor connector, through the motor, and from the other pin to one side of the front washer switch in the combination switch, and from the other side to ground. Based on this, with the ignition in the ACC position wipers should work), there should be 12 V (to ground) at one of the two pins for the front washer motor. (Same for the rear washer motor.)
Also, with the ignition Off, and with an Ohmmeter, it should be possible to check the continuity through the rest of the circuit. Once the front washer connector pin with the 12 V has been identified, check the resistance between the other pin and ground. With the washer switch Off, it should be very high. With the washer switch turned ON (might have to have someone help at this point), it should be low, not more than a few Ohms. (This won't distinguish between a problem in the switch and a broken wire somewhere, but it's a start.) If the resistance when the switch is ON is unstable, or changes each time the switch is turned on, there's probably a dirty contact in the switch.
Incidentally, the rear washer systems works the same way.
Hopefully you have a multimeter or can borrow one.
Do let us know what you find.
plain OM is offline
post #4 of 5 (permalink) Old 03-06-2011, 04:29 PM Thread Starter
kinerf's Avatar
Sorry guys ... weather has sucked since Xmas, so haven't tried anything yet. Will advise once I give it a try. Thanks for the decent responses !!! Cheers, Steven B.
kinerf is offline
post #5 of 5 (permalink) Old 03-06-2011, 06:05 PM
See this recent thread -- same problem, solution found.
Front Windshield Washers do not spray.
Let us know what you find.
plain OM is offline
post #6 of 5 (permalink) Old 03-29-2014, 08:18 PM
I have the same opportunity. My issue is in the switch assembly on the steering column. Subaru has a relay on the board in this switch assembly and that is where the failure has occurred. If you take the covers off the column three screws one on the bottom visible, and two hidden for the top cover from the bottom. You can test the the wiring and pump by grounding the larger Light green with a red tracer Wire with the Acc on. The pump will run if the wiring is good. And the fuse is the third down from the top on the left 30A in the cabin by the drivers left knee.
Kurt.Baer is offline
