No Wiper Fluid!! - Subaru Outback - Subaru Outback Forums
Old 12-10-2010, 04:32 PM   #1 (permalink)
Car: 2001 Outback Limited Wagon
Default No Wiper Fluid!!
I got into my 2001 Outback Limited this afternoon and pulled the lever to spray the windshield, but nothing came out. The wipers wipe as though something came out, but nothing is squirting. I used an air compressor to blow out the lines, they're clear. Still nothing. Also, the fuse is fine. The back one works just fine.
Has anyone else had this problem??
SoundsYummy is offline   Reply With Quote
Old 12-10-2010, 04:40 PM   #2 (permalink)
AFB77's Avatar
Car: 2005 Outback XT 5spd
1st off, do you have fluid in there?
2nd, maybe one of your lines is disconnected, did you see any wiper fluid on the ground under the car?
3rd, can you hear the pump? Maybe a wire is disconnected
4th (and this is more of an annoyance story on my part), on my 2005OBXT, I ran out of fluid one time and didn't get the indicator light saying I was running low (which my Mazda Protege used to have - a car worth 1/2 as much). As such, I told the dealer the bulb was burnt out on the indicator. He told me the car doesn't have the dashboard indicator.
I thought this was the dumbest thing, especially since I can see in the right light on the dash that the cutout is there for the indicator.
AFB77,
2005 OBXT 5spd, 22mm Whiteline RSB, GroupA endlinks, Rallitek HD springs, Rear KYB GR-2 for '00-'04 (341276), darkened rear turn signals, Front KYB GR-2 for '00-'04, Osram Rallye+65 low beams, yellow fog lights, blacked out front grill, new clutch (174,000km), new starter (179,000km)
I still lover her!
AFB77 is offline   Reply With Quote
Old 12-10-2010, 04:45 PM   #3 (permalink)
Yes, the fluid tank is full. Also, all of the lines are hooked up properly.
Old 12-10-2010, 04:53 PM   #4 (permalink)
The little pumps can burn out especially if at one point or another an operator insisted on continued pumping action when no fluid was left. No plugs or hoses disconnected and fluid in the tank - pump has failed or blown a fuse.
subiesailor is online now   Reply With Quote
Old 12-10-2010, 04:57 PM   #5 (permalink)
Thanks for the response. Do you know a good way to get a replacement pump? Is it worthwhile getting one from a scrapyard?
