2007 Outback Heat Shield - Subaru Outback - Subaru Outback Forums
Old 12-19-2010, 07:28 PM   #1 (permalink)
Default 2007 Outback Heat Shield
Ya, i know, ANOTHER heat shield.
Just curious if anyone else is having a similar issue, and if so if they have an easy fix. The weight of the snow buildup between the underbody and heat shield ripped the shield loose. I know that shield needs to be there to protect the carrier bearing and mid joint in the driveshaft from the extreme heat from the exhaust and cat.
If there's not an easy fix, I plan to make a new shield using some MUCH thicker aluminum plate. I'm assuming a new replacement shield would suffer the same fate. If I make a replacement I will definitely make it fit tighter to the under side of the body.
Maybe Subaru should have offered a "Arctic heat shield" option. In my opinion, this seems like a fairly blatant oversight, considering all of the other options the car has for winter driving conditions.
Shayne82609 is offline   Reply With Quote
Old 12-19-2010, 08:38 PM   #2 (permalink)
Car: 2003 2.5 4EAT with AWP.
I just put a hose clamp around the one of mine that had bolts rust to pieces. Cost about $3 and 15 minutes.
Old 12-19-2010, 09:57 PM   #3 (permalink)
I did that with my Dodge pickup. This one, however, is supposed to be bolted bottom of the floor, not attached to the exhaust. I think a hose clamp would rip right through this tin foil anyway!
Old 12-21-2010, 07:45 AM   #4 (permalink)
2006outback's Avatar
Car: '06 Outback 2.5i
I have the same issue. Is this shield really necessary? Mine has also been damaged by ice and slush.
What damage could be caused by removing it altogether?
2006outback is offline   Reply With Quote
Old 12-22-2010, 07:40 PM   #5 (permalink)
I know from experience (12 years turning wrenches for a living) that if the exhaust is that close to the driveshaft's carrier bearing, it will melt the rubber isolator and/or melt the seals in the bearing. Either way causing a VERY exciting failure.
I'm leaving mine off for a couple of weeks this winter. I know I will only be driving it back and forth to work for the most part. Winters here in Wyoming tend to be rather cold, so I'm hoping this will save the driveshaft till I can get it fixed.
