Stalling at stop signs after replacing battery - Subaru Outback - Subaru Outback Forums
 1Likes
post #1 of 22 (permalink) Old 12-22-2010, 11:35 AM Thread Starter
Car: 2005 Outback xi
2005 Outback 4-cyl non-turbo with automatic trans has been stalling at certain stop signs. Drove fine for 168,000 miles.
But six weeks ago after I had the battery replaced, idle speed dropped to near zero. Then 5 miles later I gassed up, at which point the check-engine light came on. Drove 20 easy miles, but the fabled relearning did not take place.
Next day, mechanic fixed the idle problem and reset the check-engine light, but said the code indicated possible need to replace the throttle actuator, a $600 part. Instead he cleaned that part. And had me come back another day when he thoroughly cleaned entire throttle assembly, hoping we'd not need that expensive part.
The intermittent stalling at stop signs continues to get worse (usually on a slight uphill), but no check-engine light except for one day last week, which prompted me to go to a dealer asking for computer reset.
By then check-engine was no longer on. Dealer verified the stalling problem, said trans fluid was jet black, did trans flush and trans re-learn, said problem "probably" solved. Also said no active codes, but one "inactive code" indicating catalytic converter.
Stalled for me at stop light 200 yards later, and continues today intermittently but gradually more frequently. No further check-engine lights. And still fails to stall when regular mechanic test drives it, or when a transmission guy test drove it on Friday. He said he found no codes. And he said since it seems to be worse early in the day it might not be a transmission problem.
If I come to a stop very gently, sometimes that prevents it stalling.
If I pump the gas when it's starting to stall, sometimes I can prevent it stalling. Risky at a stop sign of course.
If I slip it into neutral when it's starting to stall, that prevents the stall but only until I slip it back into drive.
Every time it stalls, I retart the engine easily, and at that point
it's fine.
Driving me crazy.
eridout is offline
post #2 of 22 (permalink) Old 12-22-2010, 12:51 PM
Feilo's Avatar
Car: '08 OB 2.5i MT
I have similar idle issue after I replaced my battery. Hasn't stalled out yet but came close a few times. Hope you find a resolution ...
w/ STi SS, Momo Airleather Shiftknob, Whiteline 20 mm RSB, JVC HD Radio, RalliTEK 5MT Bushings, GE Nighthawks (summer), Fumoto Valve, Group A Crank Pulley
Feilo is offline
post #3 of 22 (permalink) Old 12-22-2010, 06:25 PM
CSFiend's Avatar
Car: 03 5spd Outback wagon
Sounds like you just need to do an idle relearn. Here's a thread with a similar issue:
http://legacygt.com/forums/showthrea...e-127541.html?
CSFiend is offline
post #4 of 22 (permalink) Old 12-23-2010, 08:51 PM
Feilo's Avatar
Car: '08 OB 2.5i MT
Hmmm, thanks! Wonder how long this will take in a Chicago winter ...
Feilo is offline
post #5 of 22 (permalink) Old 12-24-2010, 08:20 AM
Feedback Score: 6 reviews
After the problem appeared, did you try disconnecting the battery again, waiting for a while, and then reconnecting?
I'm wondering if this could be a random ECM boot-up problem. When the ECM, which is basically a software-driven computer, totally loses power (including it's memory backup), it probably has to start up again when power is restored. A faulty start up (as I'm sure we've all experienced with our PCs) can lead to glitches such as is being experienced here.
The question is generated by my understanding that the Engine Control Module does not need to relearn idle; idle should be a fixed (non-volatile) parameter.
There are other parameters that are based on driving style, which are lost when power is removed. These are initially replaced by default settings and then are continuously being "relearned" over time.
Also, disconnecting the battery for replacement, recharging, storing the car, clearing trouble codes etc., is a very common occurance. If doing this were to normally result in the loss of idle function and a need to relearn, I would expect to have seen far more posts about this.
So perhaps this is just a glitch that might be corrected by a restart. (Incidentally, after the battery is reconnected, I'd give it some time for all the computers to reset fully. Then turn the key to ON but not start the engine -- this is when the OBD goes through self-checks, so I'd let it complete this process -- takes just a few seconds -- then I'd see what happens.)
plain OM is offline
post #6 of 22 (permalink) Old 12-24-2010, 08:24 PM
HOw many miles.
This can be as simple as a tired O2 sensor.
nipper is offline
post #7 of 22 (permalink) Old 01-07-2011, 12:19 PM Thread Starter
Our '05 Outback had 170,000 miles. Eventual diagnosis of the intermittent stalling-at-stop-signs problem was said by the dealer to be the need to replace the throttle assembly. But then, oh, by the way, both your head gaskets are leaking so badly you'll soon be misfiring. And that intermittent check-engine light means you better replace the catastrophic converter before your emission test next May. Proposed total: $5100. And that's without the $300 to take out the front passenger seat to replace the seat-belt sensor.
Prior problems we shouldn't have had: front axle replacement (three times). Tires destroyed (eight) due to rear alignment difficulties. And a few others I've forgotten. Oh yes, the O2 sensors -- first one, then the other.
So we found another solution, and are sadly no longer a Subaru household. We'll miss it. Thanks y'all for your help.
eridout is offline
post #8 of 22 (permalink) Old 09-26-2013, 05:01 PM
Car: 07 OB 2.5i Basic 120,000+ Miles
Do not touch the throttle pedal at all
with the engine stone COLD
and make sure ALL ELECTRICAL COMPONENTS ARE TURNED OFF.....NO RADIO...NO BLOWER...NO LIGHTS....NO AC NO NOTHING IS ON
disconnect the battery.....leave it off for 10 minutes and pump the brake pedal a few times
reconnect the battery...make sure the terminals are CLEAN and tight
DO NOT TOUCH THE THROTTLE PEDAL AT ALL
get in car
turn the key to the last position before the starter engages and WAIT 10 seconds
turn the key to start the car
leave the car to run until the radiator fans come on.......this may take 20-25 minutes
turn the engine OFF and take the key OUT of the ignition switch and wait at least 10 seconds
put the key back in the ignition and start the car and drive normally for a bit and see what happens
Controlchap likes this.
Subaroo is offline
post #9 of 22 (permalink) Old 07-06-2014, 10:48 PM
Car: 2005 2.5 SOHC
Just wanted to chime in and say that I had this issue after a battery replacement this weekend. Even after multiple restarts, the idle still wasn't adequate, and the car stalled each time I turned without throttle input. I followed the directions above to "re-learn" the idle, and all is well now.
Thanks!
blz2dwl is offline
post #10 of 22 (permalink) Old 08-16-2014, 01:32 PM
Car: 2004 Outback 2.5 manual (now sold), 2007 Outback 2.5 Manual
+1 on the above procedure. I used it today after a garage reset my CEL, resulting in the car forgetting how to idle. It worked a treat. Thanks for posting, Subaroo.
garwood1 is offline
