Hello,
I have a 2005 Outback 2.5i and the drivers-door switch broke. This is the switch which is actually fastened inside a little hole in the main chassis (not on the door itself) and the door pushes it in when closed. It has a black flexible rubber sheath which wraps around a plastic casing which clips to the switch. In my case, it is the outer plastic part which holds the rubber sheath which broke. The switch itself works fine, but it just wont stay located in the hole properly. I jury-rigged it with some duct tape for now, but I don't know how long it will hold. I think it is item #9 in this diagram, but the part number is not listed. ![]() Anybody know the actual part number? |
Looks Like P/N: 83331AG02A, try this link...
Description: PLUNGER SWITCH FRONT body FOR INTERIOR LAMPS FOR 2005-2009 LEGACY OUTBACK ALL there are two of these on the car located between front and rear doors left and right side SOLD individually Part No.: 83331AG02A Fits Model: Outback Year(s): 2005-2009 Price: $29
~Scott '05 Outback 2.5i Wagon Willow Green Opal/ Moss Green Metallic '04 KYB's all around | SpecB LCA Bushings | Whiteline Rear Camber Bushings | LGT RSB | Hawk HPS Pads | Nokian WR G2 SUV's | '08 HU | Subaru Sub Save The Manuals!
I just had this happen! Or something very similar, the driver's door wouldn't open, even with a key. I took it in and was told this was the first time they'd ever seen this. It looked fine but I couldn't flip the lock. It took 2 hours and removing the door to repair it. Mine is a 2005 Outback also.
#5 (permalink) | |
My problem was just with the little switch mounted on the chassis. With the busted switch, the car alarm didn't arm because it thought the door was still open, and the headliner/dome light wouldn't go off in the "auto" position for the same reason. |
Car: 2005 Outback Limited 2.5i
what did it take to fix your door? Sounds like mine is doing the same thing...unless you manually push the door lock knob on the inside of the door, it doesn't entirely lock.
#8 (permalink) | |
Has held up great for the last few weeks. No complaints from the wife. If that doesn't work, fish the old switch out of the hole and carefully disconnect the wiring harness - you don't want to loose the harness down inside the sheet metal! Then connect it to the new switch you bought at your local Subaru dealer and pop it in the hole and you're all set. Should take all of 5 minutes. |
#9 (permalink) |
Well the duct tape trick held for a few months, but now the rubber gasket thingy is nowhere to be seen and another bit of plastic broke off. I just ordered a replacement switch at my local Subaru dealer.
#10 (permalink) |
Car: 2006 OBXT L
Returned from a trip to find my drivers door switch carrier was broken... Battery was close to dead and the seatbelt silence mod was deactivated.
Upon further investigation someone did jam the seat belt into the door, the sticker on the jam was torn. Carrier was snapped but all parts still in place. For now I used some Krazy glue to attach the carrier to the switch. It's holding. Initially tried to just clue the carrier back together but it didn't have enough cure time or not enough surface area to hold. Disappointing that the tolerance is so slight to activate the switch. The passenger door was jacked by a friend slamming the seatbelt in the door not once but twice. The location of switch contact on the door was bent so a few mm of tape to raise this up is enough contact to press the switch. Later I'll have a body shop fix this but no time right now. Lesson learned just park the seat belt correctly before closing the door. |
