What the ^%$ is wrong with these dipsticks?? - Subaru Outback - Subaru Outback Forums
 3Likes
post #1 of 22 (permalink) Old 03-25-2011, 12:21 PM Thread Starter
Yes, dipsticks. The real kind, not the one that drives like one.. I can never get a reading thats correct on mine OR my friends 2.5 Sometimes it show NOTHING on the dipstick and I KNOW I just changed the oil! BUT if I place my 1997 Nissan trucks dipstick in, it will read just fine.
Any ideas??
kirkbrode likes this.
2point2 is offline
post #2 of 22 (permalink) Old 03-25-2011, 12:28 PM
Seabass's Avatar
Car: 05 OBXT 5eat stg1.2
I have the opposite problem. When I check it, it shows me an extra qt or 2. After letting the oil drain down the tube with the dip-stick out for 20 seconds or so, it will be accurate.
Seabass is offline
post #3 of 22 (permalink) Old 03-25-2011, 12:34 PM
Subaru dipsticks are annoying. They enter the pan at an odd angle and can read quite different on each side. I get the best reading on a stone cold engine on a level surface, but others vary.
AWDFTW is online now
post #4 of 22 (permalink) Old 03-25-2011, 03:42 PM Thread Starter
Great!, How do you even know when its correct then? I guess the answer is to use my Nissan Truck dipstick. This is bleeping lame.
2point2 is offline
post #5 of 22 (permalink) Old 03-25-2011, 04:51 PM
Feedback Score: 6 reviews
As AWDFTW noted, the dipstick goes into the engine oil pan at an angle (about 45 degrees). The top of the dipstick has an offset yellow handle that should be oriented toward the front. This will bring the flat dipstick into the oil pan with marked side ("L" and "F") facing up.
Because of the angle the oil level on the marked top of the dipstick will be lower than the level on the unmarked bottom, but they are both measuring the same thing. Use the markings on the top -- this is the correct level.
The handle also has an O-ring that provide a snug fit in the tube. This means that when the engine is stopped and the oil returns to the pan (or is refilled during a change), if the dipstick is in place, there's no vent to allow the oil to move up (or down) the tube. I found that leaving the dipstick out when filling, or while waiting for the oil to return to the pan after the engine is stopped, will provide accurate and consistent reading, hot or cold. (E.g., when filling fuel, I will open the hood and pull the dipstick up about 6-8 inches first, then fuel up, and then remove the dipstick, wipe it and send it down the tube for a reading.)
Also, I'll add that the "F" mark (actually a hole) is "full cold". The level will go up with a hot engine -- to the level of the notch that is about 1/2 inch above the "F" mark.
Granted, it's not the greatest design but necessitated by the location of the oil pan in a boxer configuration. Even the new FB engine seems to be the same, although the dipstick is moved to the front. (See attached.)
plain OM is online now
post #6 of 22 (permalink) Old 03-25-2011, 04:58 PM Thread Starter
Uhm, I call BS. The oil dipstick on a 96 2.2 and a 97 2.5 go directly into the oil pan. And there is NO excuse for a dipstick that cant read the level of oil no matter WHAT the engine configuration. I have driven air cooled beetles and porsches for years and never once had an issue with the dipstick. Its called poor engineering or lazy ass engineering, take your pick.
2point2 is offline
post #7 of 22 (permalink) Old 03-25-2011, 05:11 PM
Yes, the dipstick on the 2.5 does go directly into the oil pan on the current 2.5 series (other than the new FB). Attached is for the 2005-9 2.5 and probably other years as well. Note the sharp bend at the bottom of the dipstick tube.
Subaru's have a lot of "quirks" that new owners find strange, if not downright annoying. The difficulty in checking the oil level is one of them. As the slogan goes, "it's what make a Subaru a Subaru".
Name:	2005-9 2.5 liter.jpg
post #8 of 22 (permalink) Old 03-26-2011, 08:30 AM
bigjeep's Avatar
Car: 2009 Subaru Outback 3.0R 2004 Subaru Outback 2.5 Sedan
How true! Same here, never can get a true reading no matter what I do. Thats why we love our Subies!
bigjeep is offline
post #9 of 22 (permalink) Old 03-26-2011, 09:47 AM
tibug's Avatar
I thought I was just plain nuts. Thanks for bringing this up!
Je Suis Désolé...
tibug is offline
post #10 of 22 (permalink) Old 03-26-2011, 11:09 AM
HawkWagon's Avatar
Car: 2009 Outback 2.5i Special Edition 5M/T
Thanks to plain OM for an excellent explanation of what can be a frustrating phenomenon. I too have learned to live with inconsistent readings, by taking them more frequently and essentially averaging them out. I've noticed the O-ring but hadn't thought of the vacuum effect that would prevent travel in the tube; will try your suggestion of breaking the seal by partially removing the dipstick a few minutes before actually checking the oil level.
HawkWagon is offline
