Noisy rear end.
7K views 3 replies 2 participants last post by  ManSub
Hi all, just joined. Have got great info on issues I have been having.
I do have a recurring and annoying noise coming from the rear transmission parts of my '97 OB, she has 140,000 on the clock.
When moving at steady rpm and speed there is a whine form the rear end, sometimes it sounds more like a growl. It leaves when further acceleration is introduced. It seems worse between 45mph and 60mph. I had wheel bearings done, the left side half shaft is new the differential and transmission where serviced ( fluid and filter). No metal in fluids. Noise continues!!!?? Any thoughts.
So the noise is coming from right underneath you ? or, the rear end ... I'm not clear on that.
Also what CV was replaced, front or rear ?
This is an Automatic correct ?
Did you change the Trans fluid and the front and rear diff fluid ?
Does it sound more like a bearing noise or a gear whine ? ... both can be affected by torque [throttle] but they sound different.
Here's a little writeup on drivetrain noise.
Diagnosing Drivetrain Noise
Is it possible it could be the drive shaft. I get a clunking noise from it when you shift from reverse to Drive and vice versa. I was also wondering, if it is the differential is it best to replace the whole thing or have someone rebuild. I can do many things myself but definetly not opening a diff.
It's snowing again!!
