Reverse lights not working? (quick fix) - Subaru Outback - Subaru Outback Forums
post #1 of 13 (permalink) Old 04-11-2011, 09:00 PM Thread Starter
I have a 2008 outback and the reverse lights just stopped coming on a few months ago. I tried replacing the bulbs, but that wasn't the problem. I then thought it might be a wiring problem, and it was. When you open the trunk you can see two rubber sleeves near the roof that run from the car to the trunk. If you move the rubber sleeve you can see the wires inside and about four of them were completely severed and a few others were cracked and about to break. I just re-attached them with some butt-splice connectors and the reverse lights are good as new again. I hope this helps if anyone else out there is having the same problem. (the rubber sleeve on the passenger side is the one that had the problem on my car, the driver side wires seemed to be fine, at least for now)
highsidenj is offline
post #2 of 13 (permalink) Old 04-11-2011, 09:39 PM
Feedback Score: 6 reviews
Thanks for reporting this and how you handled it. Good troubleshooting.
There's actually a growing number of threads here about broken wires in the rubber sleeve. Sometimes it's the backup lights, or the rear wiper, or the latch not locking -- in fact I think just about all the electrical functions in the rear gate have been reported as not working with the ultimate finding of a broken wire.
But it's important that you added your experience because this will no doubt help others who have the same problem and look here for ideas.
Unfortunately, it looks as if it's likely other wires in the sleeve will also fail, so if any of the rear gate electrical functions are not working, look in the sleeve again. Also, if a fuse seems to blow repeatedly, and it powers an electrical circuit that includes something in the rear gate, it could be a broken wire at the sleeve touching ground. (Seen this with the clearance and tail light fuse, and with the brake light fuse.)
Welcome to the forum!
plain OM is offline
post #3 of 13 (permalink) Old 03-28-2013, 04:24 PM
Car: 08' Outback Limited
Just discovered this on my 08'.
Reverse lights are on when car is in park and all lights on after I shut the hatch.
When I messed with the passenger side wire bundle they went off........now they don't come on when car is put in reverse.
I probably broke the wires all the way!!!
Will report back.
Farnsrocket is offline
post #4 of 13 (permalink) Old 03-28-2013, 07:29 PM
Originally Posted by Farnsrocket View Post
Will report back.
Got in there and found the solid purple wire and the brown wire with a yellow stripe were completely severed on the passenger side.
Gonna reconnect them by soldering on an extension when I get a chance.
post #5 of 13 (permalink) Old 04-01-2013, 10:44 PM
Done and done! Everything works great!
post #6 of 13 (permalink) Old 02-03-2014, 09:08 PM
Car: 2008, LL Bean Wagon. 3.0L, NAV
Hi All
I know this is an old thread but I had the same issue with the wires. One was broken and 3 others had the insulated jacket cracked and opening up. I repaired the wires and taped all of them together. Maybe this will keep the others from breaking if all of the wires are taped together making them more ridged. Don't know for sure but we will see.
Rich
rcarter is offline
post #7 of 13 (permalink) Old 03-27-2015, 11:00 AM
I have the same problem: 4 wires are broken in the rubber sleeve.
I am trying to connect them but two out of four look exactly the same (black, thick, white dots of the same size and same distance from each other).
How can I tell one from the other?
Should I assume they are interchangeable?
Gleb is offline
post #8 of 13 (permalink) Old 03-27-2015, 01:10 PM
Someone in another thread mentioned that black wires are ground and they are interchangeable.
Gleb is offline
post #9 of 13 (permalink) Old 03-27-2015, 03:11 PM
Car: 1996 Legacy Outback 2.2L 5MT
I actually just picked up a 1996 BG Outback. Pretty good condition but the reverse lights are not working. The bulbs didn't look burnt out but I swapped them out anyway and they still didn't work. So I will investigate the wiring in the two rubber looms when I get a chance. Hopefully that is it.
Butters is offline
post #10 of 13 (permalink) Old 05-28-2015, 01:12 PM
pjcampbell's Avatar
Does anyone know which color wires do what? There's 7 broken in my passenger side boot. They are cut so close to the car side, that i only want to fix the ones that I need and just tape off the rest. I'm assuming there are extra wires for other markets...?
pjcampbell is offline
