Recruit
Anyone had problems with the over flow boiling coolant and changin the thermostat and fixing it?
Local Subaru Dealership Service guy said it's either bad thermostat or headgasket. This is a 1998 Subaru Outback Legacy 2.5 120k miles Edit: When the temp on the temp gauge goes up there is no heat out of the heater.
1993 Ford Mustang LX 5.0 1998 Subaru Legacy Outback 2004 Suzuki GSX-R 600 CBR Motorsports Cheapest Joe Rocket and HJC Dealer! |
Hokey Pokey Champion
Car: '05 Gold OBXT Stg2+
Is the coolant dirty? If it is, you're almost garanteed it's a headgasket problem.
If it's not dirty, there's a slim chance you've got something else going on (although I kinda doubt it). Is your coolant level correct? It's possible it's low, or there could be bubbles causing it to flash & blow back into the resevoir. I had this exact problem happen to me in my 97 OBW (looks like it's overheating, no heat due to an empty heater core & coolant all over the underside of the hood...filled her back up and no more problems for a few thousand more miles), but never got a straight answer on what was wrong before I traded it in, feeling it was a sign to get a new car asap. Incidentally, i had all this happen on the coldest day of the year, it was like 15 or 20 below zero with crazy winds. I assumed my thermostat froze, so I warmed it up in a garage & everything seemed fine after that. Still...it sounds ominously like a blown headgasket I narrowly escaped paying for...let us know what you find out & good luck.
When the Winds of Change blow hard enough, the most trivial of things can turn into deadly projectiles. |
Tokyo's between my toes
Yes, you are describing the exhaust-to-coolant headgasket failure symptoms perfectly. Did you also get
- water rushing/gurgling noises behind the dash - wild indicated temp swings (both up and down) Join the club, here's your membership card, expect a newsletter. |
#4 (permalink) | |
Recruit
What have people paid for a shop to do head gaskets?
As I told another member recently, use the board's Search function to look for headgaskets, head gasket, etc. There have been pages written about it here, plus many links to outside sources of information.
Recruit
Car: 1998 outback limited 2.5 dohc
my 98 obw today had the same. no heat at good temp. then i noticed a sound ,, it was spurting out of a crack in the heater core. leaked coolant onto the passenger side floor?
#8 (permalink) | |
Car: 1997 Outback Limited Wagon
I will say too that for that price it has been done perfectly. I've gone on a couple 1000+ mile road trips since then, and the car keeps the temp perfect. It takes about a minute to get to operating temp, and its not once budged from there. The shop I use specializes in Subarus, and my specific mechanic worked at a Subaru dealer for about 15 years, and builds all of the shop's Subaru race cars. He personally drives some monster Loyale thats a bizzarre DOHC 2.5 with the turbo off the old Legacy Touring sedan (2.2), and the only 360 (Subaru's microcar, not Modena ) I've ever seen personally, plus some bizarre 360 based microvan.
2005 Volvo V70R, AT, Passion Red over Atacama Leather, 17" Borbet wheels. 1997 Outback Limited, AT, Rio Red, WRX Wheels on Pirelli 215/65/16's, JVC Arsenal MP3/CD with iPod direct connect, Yakima rack with Skybox 16s Pro, JDM Legacy GT-B grille, projector headlights, sidemarkers and tail lights, PIAA 510 foglights, '05 badges. 1994 Chevrolet Beretta coupe, Vortec 3100 V6, AT, 16" wheels, 1989 Beretta GTU spoiler, Magnaflow exhaust, K&N cone. |
#9 (permalink) |
Car: 00 outback
my heads ddn't need to be surfaced, all else looked fine.
cost me a little over $250 for the timing belt, head gaskets, valve cover/bolt gaskets, fan belts. it's a little work, but that's alot of money you get to keep for something else. |
#10 (permalink) | |
Recruit
Car: 97 Outback Limited 2.5
Now that I did the head gaskets, I can't ever sell it. |
