I got this reading at advanced auto and then called my mechanic and told me the code is pretty straight forward and that is the problem. He said O2 sensors would throw there own code and some may say that there going bad but you'll only end up with the same code in the end. I was going to do the 5 minute fix with the spark plug thing.
I was also looking online at this part, is this something I could do myself or give to a muffler shop to put in? Thoughts and inputs please! Thanks!! 2002 Subaru Outback Catalytic Converter - Bosal W0133-1842851 |
Car: 2003 LLBean H6 Outback
I am all for cheating IF you check everything and cannot fix it.
A vacuum leak can cause this, and since that can cause other problems it's worth checking for. Also, an exhaust leak even after the converter can cause this code. Dave |
Car: 2003 2.5 4EAT with AWP.
I think your mechanic is wrong and whaty he told you is exactly the opposite of reality with our cars (I'm assuming you have an Outback. Year? Miles?)
P0420 is VERY RARELY a failing cat. It is most commonly a failing oxygen sensor (front Subaru, rear any brand), vacuum leak, exhaust leak or what not. Search that code on the forums and you'll find plenty of info. Cats rarely fail without serious mechanical problems, I think your mechanic wants to give you an expensive repair bill.
2003 Outback: "Kaylee". 128,000 and counting. Mods: GE Nighthawk low beams, HIR1 9011 high beam upgrade, Nokya 25k yellow fog lights, Fumoto valve, 04 Forester XT shift knob. Basics: G-Oil Bio-based Advanced Full Synthetic 5w30, Purolater oil filter, STP air filter, Valvoline Maxlife Dex/Merc ATF, Valvoline Durablend 80w90, Michelin Primacy MXV4. Also: More rust and parking lot scars than I care to think about. |
It's a 2002 subaru outback sedan 3.0.
126,000 Miles From what I've been reading replacing the O2 Sensors usually just results in the P0420 code coming back on at a later time. I don't think he's trying to take me for a ride he's helped me out a lot for free. I will def check everything over for leaks and all. In PA do they actually read the rear exhaust or do they just go off of the computer they plug into it. I was also reading that my car year is known to be over sensative with it's readings. That normally nothing is to wrong for it to throw that code, so that's why if there are no leaks I'm going to just do the quick fix. |
