2004 Outback H6 3.0 VDC replacing spark plugs. - Subaru Outback - Subaru Outback Forums
post #1 of 25 (permalink) Old 07-09-2011, 12:04 PM Thread Starter
Car: 2004 Subaru Outback H6 3.0 VDC
Hello, I am brand new to this site, have questions about replacing spark plugs on my 2004 Subaru Outback H6 3.0 VDC. What are the best plugs to use on the Outback? What gap does the plugs need to be during installment? Last question, How should I approach during replacement and installation, from the bottom or from the top? I just want to know what's the easiest route without the headaches that's all.
Thank you MUCH and Cheers!
Dmperry1974 is offline
post #2 of 25 (permalink) Old 07-09-2011, 12:17 PM
Car: 00 Outback wagon 03 VDC wagon
Try this, you will have to sign up but the site a wealth of info.
http://www.scoobymods.com/spark-plug...6-6-t4142.html
BOBOBW is offline
post #3 of 25 (permalink) Old 07-09-2011, 12:20 PM
NGK plug. Gap is .44 I believe. From under is best for most people.
Links here:
http://www.scoobymods.com/spark-plug...al-t12294.html
Also, moved to correct forum.
AWDFTW is offline
post #4 of 25 (permalink) Old 07-09-2011, 12:20 PM
Links here:
AWDFTW is offline
post #5 of 25 (permalink) Old 07-09-2011, 02:34 PM
KarlGustav's Avatar
Car: 2001 LL Bean, 1997 2.5L 5spd
The H6 specifies the NGK platinum plugs. Expensive, but I wouldn't mess around with anything else. Seems any time I've tried a non-spec plug I get misfires.
I replaced my plugs when I had the engine out of the car, so I'll be interested to hear how it goes for you. For the rearmost plugs, you may have to disconnect the engine mounts, jack up the engine, and shift it sideways. There's hardly any clearance back there.
KarlGustav is offline
post #6 of 25 (permalink) Old 07-09-2011, 05:01 PM
Car: 2003 LLBean H6 Outback
I do pretty much all my own work.
I gladly shelled out 250 or so to have the dealer do it.
Dave
CNY_Dave is offline
post #7 of 25 (permalink) Old 07-10-2011, 09:14 AM Thread Starter
Thank you all for the advise. This is my first Subie, and more to come. I have one more thing to ask, when pushing the button to turn off the VDC the lights come on right, to tell you that the VDC is off but, when driving the VDC light goes off is there something wrong with the computer? Or is that an automatic feature in the car?
Thank you much again and CHEERS!
dmperry
post #8 of 25 (permalink) Old 07-10-2011, 03:24 PM
At some speed the VDC turns back on.
Dave
CNY_Dave is offline
post #9 of 25 (permalink) Old 07-10-2011, 03:40 PM
Dogfather's Avatar
Car: 2009 Outback 3.0R Limited
Dave
I'm inclined to do the same when the time comes. Reluctantly though. Maybe I'm too cynical, but sometimes I wonder if they only do 4 or 5 out of 6 because it's a PITA for them too.
Dogfather is offline
post #10 of 25 (permalink) Old 07-10-2011, 11:26 PM
driveby's Avatar
Car: 2001 OBW H6 VDC
I did the plugs on my 2001 H6 about 40K miles ago. Should be the same as your 2004.
I did them from above. It was unexpectedly painful...but still, totally doable as an amateur/DIY job IF you have enough patience and the right set of tools.
Read these threads for details & tips:
Spark Plug H6 03 model
Flexible Spark Plug Remover/Installer
Spark Plug change, what a pig of a job!!!!!.
I've seen posts from a few folks here who suggest changing the plugs from below. I can't remember if any of them had an H6, but a 2-3 oil changes ago, I took a close look and it does look like the plugs might be easier from below. The rearmost plugs will be a pain no matter how you approach them. But next time, I'm going to try going from below first and see how that works.
Have fun!
-Jeff
p.s. As mentioned above, the manual specifies NGK platinum plugs. They come pre-gapped and in protective packaging. Attempting to gap them yourself may damage the platinum plating.
driveby is offline
