filling fuel very slow - Subaru Outback - Subaru Outback Forums
post #1 of 7 (permalink) Old 12-27-2011, 11:44 PM Thread Starter
Car: 99 Legacy Outback Wagon 2.5 5SPD
I filled my 99 Outback Wagon several times with no issues. Then one day the fuel will only go in slowly, real slowly. The handle keeps clicking off like it's full but it'll take much more fuel to fill it to the top. Any ideas?
JoeCool is offline
post #2 of 7 (permalink) Old 12-27-2011, 11:54 PM
Moved to correct forum.
These help?
Gas pump kicks off when filling
filler up please
AWDFTW is online now
post #3 of 7 (permalink) Old 12-28-2011, 05:22 PM
This can range from the simple to a huge pain...
Try disconnecting the hose from the vent valve to the charcoal canister where it connects to the canister. The canister is a black plastic box under the car behind the right rear wheel. The vent hose is the big one on the bottom.
If it fills easily with that hose disconnected, then your canister is plugged.
Try that and get back to us.
Good luck,
Wally
wallyblackburn is offline
post #4 of 7 (permalink) Old 12-30-2011, 11:35 AM
ETC
ETC's Avatar
Car: 00 OB 07 OBXT
This has happened how many times ?
If once, it's more that likely the nozzle than your car. Pumps have a return vapor circuit to the tank so, should suck the vapor back and not prematurely trigger the pump shut off. If someone "tops off" their tank and fills the vapor circuit with liquid fuel, it won't work properly until it is cleared [basically WITHOUT the pump on, pull the trigger, shake nozzle as low to the ground as you can]
ETC is offline
post #5 of 7 (permalink) Old 09-03-2013, 12:52 AM
Car: 4 Outback wagons, from 1997 to 1999
slow fill too
I have a 1999 Legacy Outback wagon. It suffers from the incredibly slow fuel fill problem. One trickles in gas for about 15 minutes. I have the gas tank out, and the tank vent valve passes air easily through from the tank side to the larger vent tube. I don't know how the smaller tube should behave or how it should be tested. There is no sign of the float sticking.
I can't seem to get my cursor to behave properly.... so I will just ask if anyone has any suggestions or furthet test ideas.
thanks
Norm
Norm in Canada is offline
post #6 of 7 (permalink) Old 09-03-2013, 08:44 AM
DavidPeab's Avatar
Car: Little Red, 2000 Outback H4 "Limited" - Onyx, 2008 LL Bean 3.0R
Feedback Score: 4 reviews
As per post #3 above, there my be a problem with the actual charcoal canister. How many miles/kilometers on your car? Have you or the previous owner continued to pump gas (top it off) any after the pump has kicked off? - when it was working normally of course. It may be the purge valve in the canister.
Set the Wayback machine to the year 2000 Sherman... when Little Red was problem free.
DavidPeab is offline
post #7 of 7 (permalink) Old 09-03-2013, 12:34 PM
Do you have any ideas as to how I test the canister and the purge valve, while the tank is out? I assume that I should be able to blow into the large vapour tube that is currently disconnected from the canister, and have air flow freely into the canister. (did I mention that I would reconnect the hose first?)
As far as the gas filling habits of previous owners.... I have no idea. At least the float on the vent valve appears to be very good, so I would hope that it would stop the gas flow before it ran into the canister.
If the purge valve failed to work, I assume that there would be a vapour buildup in the canister, which would impede the venting of the tank and stop gas from flowing in? It looks like I need a test for that purge valve for sure.
help is greatly appreciated.
Norm
