ABS light - Subaru Outback - Subaru Outback Forums
post #1 of 9 (permalink) Old 01-14-2012, 05:14 PM Thread Starter
Car: 2002 Outback Wagon 2.5
Question ABS light
Wondering if anyone else has had this problem on a 2002 outback 5MT: abs light has been on for a while with no codes showing up. Have checked all wheel sensors - all clean. Have replaced fuse and swapped out abs pump/control unit with a known good one. Wires as far as I can see look fine.
Any suggestions?
Thanks!
jonesy57 is offline
post #2 of 9 (permalink) Old 01-15-2012, 07:31 AM
Feedback Score: 6 reviews
How did you check for ABS codes? Most OBDII code readers will not access the Subaru ABS diagnostic system.
plain OM is offline
post #3 of 9 (permalink) Old 01-15-2012, 08:47 AM Thread Starter
codes
Good Morning,
I did just use the normal OBDII code reader. Any suggestions on how to access the ABS system codes?
jonesy57 is offline
post #4 of 9 (permalink) Old 01-15-2012, 05:05 PM
Normally requires the dealer's scan tool, the Subaru Select Monitor. However there is a manual procedure that I have from the 2003 service manual that might work. See attached procedure and tables of the corresponding ABS codes.
Hope this helps -- let us know.
plain OM is offline
post #5 of 9 (permalink) Old 01-15-2012, 05:40 PM Thread Starter
Smile Thanks!
This is great - thank you. I am working away from home for the next few days but will try it when I get back.
jonesy57 is offline
post #6 of 9 (permalink) Old 01-15-2012, 06:00 PM
Be interested to know if it works, and of course, if it identifies what's wrong.
plain OM is offline
post #7 of 9 (permalink) Old 01-15-2012, 08:21 PM Thread Starter
I'll keep you posted - thanks again
jonesy57 is offline
post #8 of 9 (permalink) Old 01-26-2012, 09:03 PM Thread Starter
It all worked fine - took about 2 minutes to work it out. Looks like it is the rear right side sensor. For anyone else with abs concerns this is a really quick and easy diagnostic tool.
Thanks again for your help.
jonesy57 is offline
post #9 of 9 (permalink) Old 09-04-2014, 02:30 AM
Could you repost how this was done the attachments seem to have disappeared
tlan is offline
