The front pass. side boot has a very slight seep on the axle shaft side. The boot is not damaged in any way.
Can new straps be put on and cinched tight? Are they straps or circular and need the axle off for this?
Codger |
Based on what I've read here, the straps can be replaced, but require a special tool to tighten them properly. Some have just used a screw-type hose clamp instead.
Have a look at the DIY sub-forum threads on rebooting -- that's where you're likely to find the answers. |
I did a quick Google search for boot band tool, and I see there are different mfrs of the bands that seem to require a specific tool. I would imagine that when using the proper tool for the band, it should work.
Also found this thread with a similar seepage -- but in this case the boot was replaced: DOJ sleeve leak on a 2006 outback? Let us know what you find and decide to do. This is something that comes up occasionally, and a report on taking through the full banding or clamping would be useful. |
Dude-you rock. Will try to do that. I'm doing coolant, oil and cabin filter hopefully this weekend. If I have time to go to stores, I'll look for bands and tool. If not now, I'll do it soon but wanted to kill all birds while it's on ramps...
Codger |
Car: '99 Outback SW Limited, 2.2 auto
You can find the "OEM CV joint boot clamp tool" at Autozone and similar stores.
I bought mine from Autozone (these) and personally I think it's money well invested.
'99 Outback Limited SW, 160K miles, auto |
Some (including me) also use heavy-duty zip ties. You need the black UV-resistant ones (just cuz they're tougher - no sunlight under the hood). You can get them at Lowe's Home Depot, etc.
Cinch 'em nice and tight using pliers - but not so crazy that you cut the boot. Good luck, Wally |
#8 (permalink) | |
Thanks for the link-at least I know what they're called and look like.
Codger |
#9 (permalink) | |
Yes I have used HD zips in hot places before with no problem. Never on a rotating device. Am I an old woman??
Codger |
