#21 (permalink) | |||
Car: 2000 Outback 2.5L Auto
LF: 0.024 RF: 0.114 LR:0.026 RR: 0.044 Quote:
Thanks for all your help so far guys. |
#22 (permalink) |
Car: 1998 Subaru Legacy Outback, 2.5L Automatic
I'm afraid that this thread will, ultimately, be very useful for me, lol. Thanks for sharing David!
On a side note, the daughter of a church member is doing that same ballet competition! Good luck with it! |
#23 (permalink) |
Car: 1998 Forester
Where did the dealership get the axles from? we had a problem car that i put axles in and had a vibration. Warrantied them out and still had a vibration. Swapped them with another car and the problem went away, ended up putting SUBARU reman axles in it, not a local house brand.
Sackett ASE Master Tech Subaru Tech 98 Forester |
#24 (permalink) |
What did your brake pads look like that you removed? Even wear between inside/outside pads? Uneven? Outside worn faster? Inside?
What condition do the brake hoses appear to be in? Have you flushed the brake fluid? Two purposes here; one it will clear out moisture and the color/condition will let me know where you need to go from here. Were the new rotors refaced before installation? 95% of the time, the runout of new rotors out of the box will be off. Especially Auto Zone rotors. I never use them. I have seen how they stack them and their rotors are not manufactured properly to begin with. Were the caliper guide pins cleaned and lubed when the brake repair was performed? On another level/category, what condition are the strut mounts in? |
#25 (permalink) |
Dam browser. Didn't show the other pages before I posted the above reply.
If I got this correct, you swapped the wheels and got the same runout on the right front? If this is correct, it generally indicates a bad bearing or hub. If the bearing was replaced and the hub had damage from a failed bearing and was reused anyway, it would not seat correctly in the bearing. If the bearing and hub were replaced, it is still possible that the bearing and hub were not seated proper in the spindle which would cause your runout. It is also a possiblility that a cheap hub was used and the hub is not "square". Break it down to the hub with the rotor off and check the runout on the hub. Unless you've located it by now, and if you have please let us know what you found. |
#26 (permalink) | ||||||||
Sorry about taking so long to get back to this one. Real life has once again intruded on what I want to do vs. what I need to do. I did do the valve cover gaskets with the spark plug tube gaskets, etc. I also did the timing belt with the water pump, idlers and tension arm. The smaller of the two cover pieces on the drivers side broke while I was trying to get the bolts off (they sheared off) and I had to wait 3 days for the replacement. Restored the headlights as well.
I'm not in a position to do much more with the car for a bit because I busted up my leg while turning the sailboat around in the slip for the winter (long stupid story - big boat, old dock, uncoordinated spaz). So, no car work for another 6 weeks or so. But here are the answers I can give for now. Quote:
I'd like to find another set of wheels to swap with to finally eliminate the most obvious culprit. They guy who did the road force balance told me they were just within spec. So... I'm going to let my local car guy do the hub, bearing, and spindle inspection and/or work. He does imports and Subarus and was recommended by some folks driving Gen 2 OBWs I approached in parking lots around here. I talked to him about this problem and he told me he spent weeks trying to fix it on an '01 with no success. Could this be another one of Subaru's special little quirks that makes only a Subaru a Subaru? It'll have to wait until after Christmas due to leg injury and kids wanting stuff like iPhone 5 and laptop before I do any other work on the Sube. |
#27 (permalink) |
I'm still leaning toward worn/damaged/irregular hub/bearing. That's a lot of hashes.
Its not a Subaru thing. Its a car thing. Period. When I interview my customers, and sometimes it quite fun doing it, I get them to mimick the noise. Its effective and entertaining. And they love me for it. If that doesn't do it, which in most cases it gives me an idea where to look, I drive the car and listen to it. You would be surprised at how I am able to determine a failure, or potential failure, just by the noise or noises I hear. Every part makes a specific type of noise and sometimes a series of noises when they fail. And the noises differ at various levels of the failure. You have it narrowed to the right front knee of the car. Your just spinning your wheels changing them out again. Its down to tear down one piece at a time, measure, feel and listen as you go. And put that dial gauge on the hub. Think physics: The wave enlarges as it moves outward. The bearing is at the center. . |
#28 (permalink) |
Soon. I cannot bend my knee in this cast. Therefore no dial gauging or even driving for a while. I rode with my wife today and she scares me. lol She drives a 2011 Hyundai Sonata. The car is one big blind-spot.
#29 (permalink) | |
Hyundais are what I call the throw away car. They are sold cheap. Parts cost are high. The dealers always find an "out" for warranty coverage, even down to the timeline for oil changes. The designs have gotten better for the engines, clutches, but there are still many cheap manufactured parts on the car bumper to bumper. They learned too much from Ford. |
