2005 outback Rear wiper problem - Subaru Outback - Subaru Outback Forums
post #1 of 13 (permalink) Old 10-18-2012, 11:38 AM Thread Starter
Question 2005 outback Rear wiper problem
I had my wiring harness replaced ( I had no rear wiper or backup lights) turns out the wiring harness was the problem. Once replaced all works fine; except
My problem now is the wiper won't automatically return to the bottom of the rear window. If I use it on intermittent it returns to the base of the window, but not if I turn it on any other setting.
Can wiper system be reset by disconnecting both battery post.(like rebooting your PC or router) I know this works to reset a check engine light. I am thinking this because the wiper blade stops where it was when the wiring harness broke and shorted out. I can just try it but wanted to share this because the service manager said the motor was wearing out. This I doubt I have a 1995 legacy wagon and the wipers all work fine. Subaru makes a better car than most. (I have owned Subaru since 1978) and someone else might have a different idea as to this problem.
macnore is offline
post #2 of 13 (permalink) Old 10-18-2012, 06:50 PM
Feedback Score: 6 reviews
Did the problem appear right after the harness was replaced? If not, then how long was it between the harness being replaced and the problem first being noticed? (I'm wondering if perhaps the wiring has failed, once again.)
I'm not certain about the way the wiper is controlled, but from the wiring diagram there are several fuses that power the wiper system that should be verified. These are:
Fuse #8 in the engine compartment fuse panel;
Fuse #7 and fuse #23 in the in-cabin fuse panel (to the left of the steering column).
Fuse #23 powers the wiper as it returns to the parking position after the switch is turned off, and it also powers the rear washer pump -- have you tried the washer? If it doesn't run, fuse #23 might be blown.
(See the Owners Manual for fuse panel diagrams with fuse #s.)
plain OM is offline
post #3 of 13 (permalink) Old 10-18-2012, 09:00 PM
Car: 2003 LLBean H6 Outback
Wiper motors usually always get +12V and the switch/intermittent circuit grounds the other (-) side of the motor, and then a commutator keeps the motor (-) side grounded until the wiper is in the park position.
So, of anything is funky with any grounds, the wipers can do odd stuff. there is a ground lead right at the wiper.
CNY_Dave is offline
post #4 of 13 (permalink) Old 10-19-2012, 08:49 AM
Wiper motors usually always get +12V and the switch/intermittent circuit grounds the other (-) side . . .
Perhaps on some makes, but it appears to not be the case with Subaru. Attached is the 2005 wiring diagram for the rear wiper where the negative side of the wiper motor goes directly to ground and the 12 V supply is switched. I also checked a number of Subaru wiring diagrams from 1995 to 2011, and they're all the same ground side configuration.
In the attached diagram, FB-23 and FB-24 (at the top of the diagram) are switched 12 V lines that are powered when the ignition switch is at ACC or ON. When the wiper switch is turned to ON, pin C6 of the BIU is grounded. The BIU then connects 12 V to the motor from connector pin B1 to wiper motor connector pin 2. As the motor begins to turn, the internal switch moves from the Off or rest position (as in the diagram) to the other side, connecting the 12 V at motor connector pin 5 to motor connector pin 4, and from there to the BIU connector pin B8.
The motor internal switch remains "On" whenever the wiper arm is away from the parked position. Consequently, there's 12 V at BIU pin B8 whenever the arm is off park. Now, although I'm not sure how this works internally inside the BIU, as long as the wiper switch itself is at ON, the BIU continues to provide power to the wiper motor. However, when the wiper switch is turned Off, the BIU senses whether or not there's 12 V at BIU pin B8, and as long as there's 12 V there (coming through the motor internal switch), it continues to power the motor. But as soon as the wiper arm reaches the park position, the motor internal switch will toggle over to the Off side, opening the circuit from motor connector pin 1 (12 V) to motor connector pin 4 (to the BIU) and grounding BIU connector pin B8. At this point, the BIU cuts the power to the motor thereby stopping the arm at the park position.
In intermittent operation, BIU connector C18 is grounded by the wiper switch and the BIU powers the wiper motor, but in this case only for one cycle. Again, it uses the motor internal switch to signal when the wiper arm is back at the rest position after the first sweep at which time the wiper motor stops running. The BIU then waits a set time, and starts the single cycle over again.
The stopping point for the wiper arm is determined by the motor internal switch that's mechanically connected to the wiper arm shaft drive mechanism, and it's the same whether the wiper had been running with the wiper switch in the Intermittent or On position. (This makes the OP's description somewhat puzzling to me, as it should be the same. See Rear Wiper Does Not return to Park or Home Position for a previous case.)
Incidentally, the use of the BIU adds an additional feature -- when the rear wiper is in Intermittent operation, if the transmission is set to Reverse gear, the BIU will run the rear wiper continuously instead of stopping after each sweep.
Name:	rear wiper 2005.jpg
plain OM is offline
post #5 of 13 (permalink) Old 10-19-2012, 10:22 AM
That pic isn't so clear to me, looks like the switch connects various leads to ground to activate the wiper etc.
CNY_Dave is offline
post #6 of 13 (permalink) Old 10-19-2012, 10:34 AM
Novablue's Avatar
Car: '15 FXT
There are so many connections there is a lot to go wrong there. It would be nice to see what is actually happening. It almost sounds like the harness got plugged in wrong or is the wrong one.
Don't discount the fact that the motor is going out. It's 17 years old. Personally I too would do more checking before replacing it.
-Dave
Common sense, isn't common.
Current: '15 FXT
past '12 2.5L OB
Novablue is offline
post #7 of 13 (permalink) Old 10-19-2012, 10:41 AM
The diagram shows the motor internal switch in the "rest" position, that is, with the wiper switch Off and the arm at the proper location. In that case, the switch is connecting pin 4 of the motor connector to pin 3 of the motor connector, which goes to ground. This is the only ground connection through the switch, and this is only in the "rest" position.
The motor itself is connected between motor connector pins 2 and 3. As pin 3 is wired to ground, in order for the motor to work, 12 V has to get to pin 2. The motor internal switch isn't connected to pin 2. So the 12 V has to come from the BIU (BIU connector pin B1). As soon as the motor starts to run, the switch toggles over, so that the ground connection in the switch (lower side going to motor connector pin 3) does nothing. But the then continuity between motor connector pins 1 and 4 (through the toggled internal switch) provides 12 V from FB-23 to BIU pin B8.
plain OM is offline
post #8 of 13 (permalink) Old 10-19-2012, 10:45 AM
Indeed. That's why we need to know if the problem appeared shortly after the harness was replaced, or a good time later, with the wiper operating properly in between (although I would hope the operation of the wiper would have been checked when the harness was replaced).
plain OM is offline
post #9 of 13 (permalink) Old 10-19-2012, 01:21 PM
BTW if it is the wrong harness, if the right set of circuits is energized (or de-energized) a short to ground could be created.
CNY_Dave is offline
post #10 of 13 (permalink) Old 10-19-2012, 02:19 PM
wilsonhp's Avatar
Which should instantly blow fuses....
wilsonhp is offline
