#21 (permalink) |
Agreed. Your idea of refilling with slightly less will be fine. As long as the level is somewhere between the L and F marks it's good to go. We're just a bit picky, and want it right at the mark. But even that's a challenge because the level changes noticeably with ATF temperature.
#22 (permalink) |
Car: 2011 Subie 3.6R Limited 2013 Cmax e=nergi PHEV
Well after a week of taking measurements daily I have determined that the ATF hot level is at least 3/8" high above the hot high hash everytime. When cold (depends on how vigorous I go through the gears, just D and R or all the 1-5 and R, the level is between 1/8" under and 1/8" over the hot high hash hole.
Not really sure how cold a cold ATF measurement can be. By the time you get the car through the gears it is the coolant at least is warm. Not sure about the tranny. Guess a good cold measurement is just R and D and then a couple measurements while in P (which renders a reading at or slightly under the top Hot hash. The ambient temp has fluctuated from 90F down to 60F which may have a slight effect on the fluid's expansion and contraction. Bought a hand pump to take a little more fluid out through the dipstick tube and set a baseline lower on the stick before I do the change. Hopefully the slight factory overfill will not have caused permanent damage to the tranny. Hoping as a few have posted that the tranny was engineered with a slight overfill capacity. As Novablue wrote "you never know," which is why these simple fluid changes will be done by me. That "never know" feeling doesn't inspire confidence.
2011 3.6R Limited Curt 2" Hitch, Garmin ecoRoute HD OBDII, Weathertechs, Fumoto Valve, 19mm RSB I-pod controller, Exhaust Tips, RSBP, F&RCBM 2013 Cmax e=nergi phev |
#23 (permalink) |
I pumped out about a quart total to get the dipstick properly between the HOT High and Low hashes hot, and the COLD High and Low hashes cold.
Be warned and don't be a dipstick like I was and wait to check your ATF. Check it before you drive the car off the lot. In the hashes after draining a quart and running through the gears up and down on the freeway. HOPEFULLY my tranny won't die early. The fluid was chocolate not a pretty shade of red. I went ahead and did my change with 4 fresh quarts. Not sure if I should do several changes to cycle out the ATF quickly or just go to the 4 quart drain and fill every 15k?
#24 (permalink) |
The Subaru ATF-Type HP does tend to change from a reddish color to a honey-brownish look. This is considered normal.
I do a drain and fill (~4 qts) annually, and the drained ATF is usually quite dark (tending toward black) when looked down at in the catch container. But when I put it into an 8 oz clear measuring cup, and hold it up to natural light, the reddish color is apparent. It depends on how it's viewed. Here's a pic with new on the right, old (about 10k miles) on the left.) ![]() and here's the same "old" held up to a window. ![]() The chocolate color could be "normal". A usual question would be: does it smell burned? If you're concerned, why not do a few drain and refills, with running the engine for a few minutes in between (or some driving). After the second the drained fluid should be more like the new fluid, so the third refill finish the cycle. |
#25 (permalink) |
Thanks for the great color shots^.
Mine looked like poo. Totally brown. Not a hint of reddish tint. Lots of mountain driving and 35K. I am wondering if I should cycle the fluid out or just go to a 15K interval? Link to ATF change pics:DIY: Gen 4 3.6R ATF Drain and Fill
#26 (permalink) |
I'd probably do a few drain-and-fllls to ensure that what's in there is mostly new (establish my own benchmark) then I'd go to the 15 K routine and see what comes out. But that's more or less what I do.
The service manual doesn't call for frequent changes, and many go far, far more than 36k without touching the ATF. |
#27 (permalink) |
^Thanks for the input and advice. I changed ATF pans and filters after 30k plus intervals 3 times on an F-150 with Merc/Dex or whatever it required. The stuff was always clean and red. So my Subies tranny juice color combined with the overcapacity level before setting a baseline has been a bit scary.
The one good thing is that I have my level where I want it. I am not sure I want those remaining (~6.4) quarts of liquid chocolate in the $$$ tranny. Anyone got pics of ATF after 30K miles? If so please post. Almost want a quick valve on the AT about now if I am going to flush it out with new sauce. I liked the way PlaimOM's fluid looked after 10k (still rosy) a lot more than mine did after 35K. YUK.
#28 (permalink) |
Car: 2012 Outback 3.6R
FWIW - after 16K miles the factory ATF fill, when properly checked, also pegs about 1/2" above the hot high hash mark. Subaru service dept said this was not a problem - no explanation why the factory might overfill, but no worries mate.
I understand that the transmission fluid runs in a open reservoir and is not under pressure like the engine oil system. But I will drain a pint or so to get a proper hash reading when I do my ATF change next week. |
