#11 (permalink) |
3M Window Weld. You can pick it up at just about any parts store. Its what is used to attach and seal the windshield. A tube that fits in a caulk gun runs about $25.
Be sure to write up a scenario of your experience.... |
#12 (permalink) |
Car: 2000 Outback 2.5L Auto
The stuff I mentioned in my last post worked to eliminate the kazoo sound I reported in my first post. We'll see how long it lasts for that problem.
I also used it to seal 98% of the gap between the bottom of the back glass frame and the top of the center "Subaru" logo plastic piece. If it doesn't keep the water out of the hatch during the next big rain, I'll clean it out and use the 3M product mentioned above. |
#14 (permalink) |
I must have misunderstood where the noise was produced. I assumed it was where the inside (windshield side) of the windshield gasket lay down on the windshield. See #1 in attached pic. So I added a bead of that filler crap I mentioned earlier in this post to keep air from slipping up under that trim. The silicone would be easy enough to remove if I need a new windshield. That did not help. Today the kazoo is back.
![]() Should I be filling the huge gap (#2 in pic) under the outside edge of the rubber windshield gasket and the frame of the car using the 3M black stuff mentioned above? As you can see there is enough room between the edge of the windshield and the metal of the car to run a coax cable.
#15 (permalink) | |
#18 (permalink) | |
I inherited the car from my sister-in-law when she died. She didn't "take a liken' to me" as they say in West Virgina, where she and the car were from. Every time I have a problem with it - and I've spent the last 9 months fixing all the ones I inherited - I feel like it is her ghost haunting the car. As each problem is fixed I feel like I am doing a small exorcism. She IS telling me to slow down, but only when an 18 wheeler is riding up my back bumper. RIP Sarah. |
#19 (permalink) |
Cheesehead
I very occasionally get a similar sound. Usually when there is a strong cross wind, when I'm traveling at highway speed. It's the passenger wiper assembly vibrating on the windshield. The wind get under it a little and lifts it up and down making a rather loud buzzing/vibrating sound. I learned to ignore it after I figured out the cause......
#20 (permalink) | |
I called a local windshield place and they said they'd send someone out within 48 hours. They're kind of busy still from hurricane Sandy. |
