2005 h6 ect - Subaru Outback - Subaru Outback Forums
Old 12-05-2012, 03:41 PM   #1 (permalink)
Car: 2005 3.0 H6 LL Bean
Default 2005 h6 ect
Can someone tell me or take picture and show me where the engine coolant temp sensor is on a 2005-2009 H6? Getting the C0115 error code and my coolant system had an air pocket in it after shop replaced the radiator, which caused it to overheat. Guessing it cooked the sensor.
2005 3.0 H6 LL Bean
Narcosis is offline   Reply With Quote
Old 12-05-2012, 05:02 PM   #2 (permalink)
Might want to double-check that code. "C" codes relate to the chassis, and C0115 is for an ABS wheel sensor problem.
Was/Is the check engine light on or flashing?
Old 12-05-2012, 05:14 PM   #3 (permalink)
Hmm, thanks for that. I have a C0115 and C0107 code. The Check Engine light is solid with the Cruise light flashing. I also have the dreaded P0420 code for the cat system.
2005 3.0 H6 LL Bean
Old 12-05-2012, 07:17 PM   #4 (permalink)
C0107 Abnormal signal of front ABS wheel speed sensor RH
C0115 Abnormal ABS wheel speed sensor on any one of four sensors
P0420 -- lots of discussion here -- search for the code and set aside time to read, but start with this thread: P0420 Diag
If the P0420 is current, the CEL will be on. Cruise is automatically disabled when the CEL is on, consequently the flashing cruise light.
Old 12-05-2012, 08:25 PM   #5 (permalink)
P0420 - simply install the $5 fix and be done with it. it's too much of a debacle to otherwise worry about.
if you really want to put some effort into - first simply seal up any leaks in the exhaust system.
ABS sensors may just need cleaning, sometimes they can have debris stuck all over them.
Otherwise they're attached by like one bolt and then another bolt or two for a bracket just to hold the wire and super easy to replace. 3 bolts, a few minutes, very easy job.
If any recent work was done, make sure it's plugged in and fully seated (unplug it and plug it back in).
Old 12-06-2012, 08:31 AM   #6 (permalink)
cardoc's Avatar
May want to have the bearing checked on the suspect wheel reporting an error.
