2000 Legacy OBW, electrical possession. - Subaru Outback - Subaru Outback Forums
Old 12-13-2012, 07:29 PM   #1 (permalink)
kybishop's Avatar
Car: 2006 H6 3.0R LL Bean wagon.
Default 2000 Legacy OBW, electrical possession.
I have had this Outback Wagon a good long while, many years and got it with about 30,000 miles on it.
Today I smelled something like burning or hot electric smells when I got in the garage at work returning from lunch. I determined it was coming from the vents. Certainly not something you want to smell but not uncommon in older cars from time to time. No smoke and not strong smell, faint.
Driving the car home I noticed the smell again. I pulled over and tried to locate it under the hood. No smoke and could smell something but could not locate it. Seemed most prevelent on the drivers back side. Lot of the electrics are right there.
I am only about 3 miles from work to home so I proceded home. As soon as I pulled in the driveway it started with a lot of crazy stuff.
Every time I pushed on the brakes it emitted a noise out of the stereo speakers. Stereo turned on and off a few times, AT/oil temp light flashed and flickered, check engine light came on and off, ABS light came on and off, tach and gauge reading went out and back on. All this with in a few seconds of coming to a stop. The whole time idling and running just fine, great as always. I shut it off.
I could still smell the burning but could not locate it. I don't know where the fusible links are, that is where I was going to start. Fuses in the fuse box looked fine and no smells there.
I guess it is going to just be a matter of tracing this through checking all the grounds, connections and harnesses? Where would one start?
Thanks.
The herd;
1986 Subaru GL wagon dual range 4X4.
2000 Subaru Outback Wagon
2006 Subaru LL Bean Wagon
1978 Dodge Ramcharger soon to have a Cummins 6BT.
1992 Dodge CTD beater/doner.
1994 Landcruiser FZJ80
kybishop is offline   Reply With Quote
Old 12-13-2012, 10:41 PM   #2 (permalink)
Car: 2000 Outback 2.5L Auto
Alternator?
DavidPeab is offline   Reply With Quote
Old 12-13-2012, 10:58 PM   #3 (permalink)
rasterman's Avatar
Car: 2006 Outback XT Limited
Start with some voltage measurements. It does sound like the alternator is dying and failing to regulate voltage presented to the car, some measurements will help confirm. Without the smell component I'd be more inclined to say bad ground.
Sample it at the battery engine off, at idle and at speed.
Some auto parts stores will test an alt for free, consider it if you know you are near one that does.
DBA slotted Legacy GT front rotors w/Carbotech 1541 front pads; Hawk HPS rear pads and SS hoses
rasterman is online now   Reply With Quote
Old 12-13-2012, 11:21 PM   #4 (permalink)
kybishop's Avatar
Default Thanks.
Thanks guys. That sounds like a possibility and an easy check. It could be the alternator frying away and smelling as it is failing.
All my alternators in the past just flat quit working and just let the battery go down all the way or the car just died. Never this dramatic so I didn't think about it being this simple. Lets hope so and I will give it a check.
I replaced it a few years ago I think. But, these rebuilds and remans can be pretty poor these days and not last very long. I can't remember exactly when I replaced it and where I got it. I can check that too though.
The herd;
Old 12-13-2012, 11:58 PM   #5 (permalink)
rasterman's Avatar
Subie alternators rarely just quit. They like to take hostages, issue ultimatums, negotiate deadline extensions, throw inappropriately themed parties and more until you decide you've had enough.
Power corrupts.
Old 12-14-2012, 08:03 AM   #6 (permalink)
Do you have an aftermarket alternator in there? I just had nearly the same issue on mine and replacing the alternator solved it. Aftermarket alts on these things have a tendency to fry out apparently.
sinisterplaydough2 is offline   Reply With Quote
Old 12-14-2012, 10:17 AM   #7 (permalink)
canubaru's Avatar
Power corrupts.
i'm saving this one.
Old 12-14-2012, 10:39 AM   #8 (permalink)
cardoc's Avatar
Power corrupts.
That's so true. If they could take your wallet and run off with it, they will.
Wait, on the H6, they do.
Sounds like an overcharge condition. You'll want to replace the battery, alternator and check for blown fuses and the cables on the rear of the alternator. The regulator on this one is controlled by the ECM.
Be sure the replacement alternator is a Mitsubishi specifically for the H6.
Old 12-14-2012, 01:24 PM   #9 (permalink)
kybishop's Avatar
Default Thanks.
Thanks for all the input from everyone. I haven't had an opportunity to look at the car again as I am at work. But, it is Friday! I will try to look at it tomorrow in the morning. Won't have time this evening.
And, this is for my 2000 OBW with the H4 not the 2006 with the H6. Thanks for the message though as that helps me prepare myself for H6 alternator replacement if ever it should present itself. It sounds expensive...
I have found that these for the H4 are about $230 for an OEM reman from Subaru parts for you that is with the core returned. I went there as I have had good luck with them in the past. I have found some in the local salvage yard for $50 too. They say they have it, I have not seen it yet.
The herd;
Old 12-14-2012, 01:27 PM   #10 (permalink)
kybishop's Avatar
Default Hmm.
I am not quite sure. I will have to give it a look and I will let you know. I am curious myself. It was replaced about 3 years ago. At that time car just flat quit running. No drama, no warning. Sitting at the light idling one minute, off the next.
The herd;
