#12 (permalink) |
Car: '99 Outback 2.5 GT auto & '97 LegOB w/ grossly insulted 2.5
The shiny portion of the debris reminds me of British motorcycle gear boxes I have failed. I wrote those off to poor under-surface gear hardness. With the ability of these cars to handle slippery conditions; could transitions between spinning & high traction be exceeding the robustness of the differential pinions? Have a '57 Chevy that wheel-hopped & broke these gears until heavier rear spring main leaves stopped the wheel-hop. I've considered all pinions with a prejudiced eye ever since.
#13 (permalink) |
Car: 2003 LLBean H6 Outback
The lucas didn't change the noise, and it hasn't gotten worse... yet...
I've been careful to not spin the tires when transitioning from low traction areas to high traction areas. I did in a worn '92 ranger drive shaft that way once... Noise started over the summer. |
#14 (permalink) |
Noise with rear wheels on the ground and not moving:
I think this is definitive, front pinion bearing. I also confirmed even in 1, there is NO drive to the rear wheels until you step on the gas (whern I had all 4 off the ground, heh) |
#15 (permalink) | |
#16 (permalink) |
Yeah, 90% FWD until something slips, but 1, 2, and R make it much more evenly split as soon as slippage occurs.
There was controversy, though, about when you put it in 1, 2 or R if it was 'locked' into 50/50 (MPT as engaged as it ever gets, anyway) or if slippage had to be detected first. Even so, it was much quicker to drive the rears in 1 than in D, so 1 is certainly better for grip than D. |
#17 (permalink) |
We covered this in quite some detail in the FreeSSM thread. Lots of data on where the AWD control duty cycle signal is under different conditions.
The control responds not only to slip, but to risk of slip represented by throttle position, engine torque, wheel speed, gear etc. You don't need any wheel slip to see the control go from the base level of around 30% duty cycle (which in itself is significant) way up to 90% or more based only on throttle position. That's what distinguishes the Subaru full-time AWD from other makes that are in fact FWD until slip is detected and then they go switch to AWD (it's either on or off, without anything in between as with the Subaru.) In 1st gear, the rate at which the duty cycle responds to factors other than actual wheel speed differences (aka slip) is faster than in the higher gears, but that corresponds to the fact that torque to the wheels in the higher gears isn't as great as in the lower gears, so the risk of breaking traction in the lower gears is higher. It's a fascinating and very responsive system when it's working. |
#19 (permalink) |
On the way home last night I thought I may have smelled gear lube.
Pulled the car in the garage last night, am starting the trans swap. There's oil under the car. I'm goin' in. |
