1996 Subaru Outback Wiper issue - Subaru Outback - Subaru Outback Forums
Old 01-06-2013, 11:46 AM   #1 (permalink)
Unhappy 1996 Subaru Outback Wiper issue
Hello, we currently have a 1996 Subaru Outback that the wipers stopped working...ugh. How to fix??? Anyone know or be able to walk me through it.
Helpme is offline   Reply With Quote
Old 01-06-2013, 12:31 PM   #2 (permalink)
canubaru's Avatar
check the fuse?
Old 01-06-2013, 01:13 PM   #3 (permalink)
Default yes
yes have checked the fuse the motor runs but wipers don't go...
Old 01-06-2013, 09:19 PM   #4 (permalink)
The crank has probably come loose.
Lift hood. Pull up plastic cowl cover on passenger side.
There is an oval rubber plug.Remove it.
You should be able to see an aluminum crank just laying there. It has a plastic cup on each end. it should snap back on to the end that comes from the motor. You can move the wipers by hand to get it to the right positiion.
The plastic ball will sometimes break and in that case get an arm from the junk yard. You'll need a 14mm socket to remove the wiper arm and a 10mm to remove the center pivot that connects the two arms. The arms are different lengths, so you'll have to get the one that matches the busted unit.
O.
Osei is offline   Reply With Quote
Old 01-06-2013, 10:49 PM   #5 (permalink)
Default Thank You
Thank you will look into tomorrow!
Old 01-06-2013, 11:46 PM   #6 (permalink)
there may be some help from the parts store. Try searching on the issue cause, I recall some people were able to get an aftermarket part work under certain circumstances.
(can't recall if it was a 'universal' plastic ball, or for a different car. maybe someone else will have details)
Old 01-07-2013, 10:10 PM   #7 (permalink)
When I removed the cover, it was solid metal... How do I get to the plug?
Old 01-08-2013, 12:10 AM   #8 (permalink)
various amonts of related help from a search - maybe some of it will apply to your car;
Windshield wiper clunk - Subaru Forester Owners Forum
Wiper Problem - Page 2 - NASIOC
('98-'00) DIY Wiper Bushing Fix - How to stop those clunking/slapping wipers! - Subaru Forester Owners Forum
you might email this guy to see if his repair clips might work for a subaru; WINDSCREEN WIPER MOTOR LINKAGE REPAIR CLIP FIAT PUNTO - IMPROVED VERSION | eBay
Old 01-08-2013, 08:38 PM   #9 (permalink)
Will do, thank you for your help!
Old 01-08-2013, 08:49 PM   #10 (permalink)
canubaru's Avatar
a fairly common problem especially due to heavy snow is for the spindle nut at the base of the wiper arm to be a little loose. this allos the motor to turn the spindles but the arms to not move. but probably not likely for both to be lose at the same time. but still worth checking.
