I have a 2006 outback xt with 80,660 miles. Check Engine light and flashing cruise control started flashing.
Our mechanic diagnosed it as needing a new cat converter and O2 sensor. We have to call the dealership tomorrow to see if it is under warranty. Anyone have warranty info for this year and model? I can not find anything on the web. |
The emission system including the ECM is covered for 8/80k, but I don't know how much Subaru will be a stickler given your just over 80k, but they will go over the car more than a "mechanic" to insure the CAT does indeed need to be replaced before replacing it. The CAT on your car is not cheap.
You may not need a CAT. Get a second opinion. Read through here for some ideas: P0420 Diag |
Car: 2003 2.5 4EAT with AWP.
The likelyhood of it actually being a failed cat is extremely low.
Commonly a failing O2 sensor, or exhaust leak.
2003 Outback: "Kaylee". 128,000 and counting. Mods: GE Nighthawk low beams, HIR1 9011 high beam upgrade, Nokya 25k yellow fog lights, Fumoto valve, 04 Forester XT shift knob. Basics: G-Oil Bio-based Advanced Full Synthetic 5w30, Purolater oil filter, STP air filter, Valvoline Maxlife Dex/Merc ATF, Valvoline Durablend 80w90, Michelin Primacy MXV4. Also: More rust and parking lot scars than I care to think about. |
#5 (permalink) | |
thanks! |
Car: '05 Outback 2.5 XT Limited, '09 Outback Sport, '13 Outback 3.6R Limited w/SAP & Brilliant Brown Pearl
In my case on my '05XT I got a code virtually the same and was also saying it was the Catalytic Converter. The engine was running somewhat lousy too. However, mine ultimately turned out to be a bad exhaust gas temp sensor. They also had to replace the "Pre-Catatalytic Converter Pipe".. whole thing cost around $350.00. The code went away..
Steve
"There is nothing wrong with your mind, you really have reached the end of the Internet... We hope you have enjoyed your stay. Your next stop is the twilight zone. From this day on you will be totally under our control." |
#8 (permalink) |
The codes listed on the service receipt from the dealership were:
P0030 O2 Sensor heater circuit range/performance problem; and P0134 O2 Sensor Circuit open (bank 1, sensor 1) My mechanic had 2 codes these listed as well as: P0420 Catalyst efficiency below threshold level bank. Hope this helps and thanks for the help! |
#9 (permalink) |
My guess is still gonna be a failing front oxygen sensor. Not too difficult to replace with a oxygen sensor socket, PB Blaster, and time.
#10 (permalink) | |
Also check the ground lug on the intake manifold, right side up top close to the throttle body, and make sure its tight and clean. |
