2005-2007 Outback Standard Maintence - Subaru Outback - Subaru Outback Forums
Closed Thread
Old 12-22-2006, 03:02 PM   #1 (permalink)
Hokey Pokey Champion
JazzyMT's Avatar
Car: '05 Gold OBXT Stg2+
Default 2005-2007 Outback Standard Maintence
Maintenece Schedule
There are a few things I would change about this schedule, like replacing your transmission oil and differential oil every 60k miles no matter what, etc., but it's a good starting place.
When the Winds of Change blow hard enough, the most trivial of things can turn into deadly projectiles.
JazzyMT is offline   Quick reply to this message
Old 12-22-2006, 03:03 PM   #2 (permalink)
JazzyMT's Avatar
Engine Oil Replacement
Old 12-22-2006, 03:04 PM   #3 (permalink)
JazzyMT's Avatar
Engine Oil Filter replacement
Old 12-22-2006, 03:04 PM   #4 (permalink)
JazzyMT's Avatar
Spark Plugs - V-belts
Old 12-22-2006, 03:05 PM   #5 (permalink)
JazzyMT's Avatar
Timing Belt
Old 12-22-2006, 03:05 PM   #6 (permalink)
JazzyMT's Avatar
Fuel Line Inspection
Old 12-22-2006, 03:05 PM   #7 (permalink)
JazzyMT's Avatar
Air Filter Element
File Type: pdf 08 - air cleaner element replacement.pdf (92.6 KB, 1632 views)
Old 12-22-2006, 03:06 PM   #8 (permalink)
JazzyMT's Avatar
Cooling System Inspection
Old 12-22-2006, 03:06 PM   #9 (permalink)
JazzyMT's Avatar
Engine Coolant Replacement
Old 12-22-2006, 03:07 PM   #10 (permalink)
JazzyMT's Avatar
Clutch Inspection and Adjustment
File Type: pdf 11 - clutch inspection & adjustment.pdf (39.2 KB, 1230 views)
Closed Thread
